o00scorpion00o
Thanks, I see the donate button. I will have to do something like this.
What do people think about installing the setup in a pump house for well ? It will be easier than installing cables in the attic, but I may end up going to the attic. Not sure yet.
The Antenna will be the Bonito FX 10 Meter Loop.
- o00scorpion00o
- 351
- ReadOnly
- 17
Thanks will watch out for NPO.
struggling to find Polystyrene caps, can I use ceramic instead ?
Thanks Martin, will get ordering tonight hopefully. Cheers Mark
Ok thanks for the advice lads, will hopefully get around to ordering parts at the weekend. If I were to go with a premade inductor can anyone send me a link via this site as to which would be best for this please ? https://ie.rs-online.com/web/ Or …
lol I'll try not get carried away, looks simple enough, will take time to get all the parts. How many turns is reasonable for one of those T50-2 ? I've read that silver Mica are the best to use in these applications, gives higher Q but getting one…
Ceramic vs Mica ?
"This is the circuit that was created by me, I based it on an lower and upper cut off based on the bandwidth of the 252 Khz signal or should I just input 252 Khz with no upper and lower ?" I meant calculated by the software on the website …
This is probably the simplest I can find then ? https://goodcalculators.com/resonant-frequency-calculator/
nearly 60 dB over so probably want at least 20 dB reduction ?
Based on the above link this is the filter it designs for me. https://forum.kiwisdr.com/uploads/285/IEHUSKIO9Q3A.jpg This is the circuit that was created by me, I based it on an lower and upper cut off based on the bandwidth of the 252 Khz signal or…
Will do Martin Cheers.
Thanks, I will see if I can get the parts locally.
Here's another site I discovered. http://www.wa4dsy.net/cgi-bin/lc_filter4?FilterResponse=Bandstop&poles=6&CF=252&cfunits=KHZ&cutoff=10&funits=KHZ&Z=50
I have a few FT-240 31 cores lying around, could I use those ? What wire should I use ? I read that thicker will increase the Q ? What about capacitors ?
According to this I need 5000PF caps and 80uH inductor. How many caps is the question ?
I found this on my travels for a "quick solution" lol https://www.dxing.com/tnotes/tnote06.pdf and this https://www.youtube.com/watch?v=Tx7eeIgKtX8
"It's also a pity that so many folks who have paid good money and installed KiWi's don't seem to have paid much attention to the antenna system." The antenna is fine, don't need any solutions for the Airspy HF+, it works just fine with thi…
Thanks for the replies lads, yes I had a thread on it a few years back but my main issue is time, I don't have the time for tinkering around with stuff. Working 5 days a week, Kids and 10-12 hrs on the road commuting, + work around the house/ big ga…
Hi John, No, no back and forth LEDs, yes I can try hold down the boot button, I will try with my 2nd Kiwi while I try decide how I am going to mount the antenna for this.
Update, I remembered I had another old 4G modem lying around with the same 192.168.8.xx address range so I connected the Kiwi to this and got to change to DHCP.
Thanks, I have extracted the Debian 10 image and loaded it onto the sd card with Pi Imager but the BBB will not load this image, I have waited well over 1 hr but it did not flash the BBB with the new image. Any ideas ? should the kiwi board not be…
Hi All, just discovered this thread, I think I can shed some light as to who is using our Kiwis with the name kiwirecorder.py. I was first contacted by him in 2018 after I noticed he was using my Kiwi for several hrs per day and I had no limit at t…
http://forum.kiwisdr.com/index.php?p=/discussion/comment/11750#Comment_11750 Thanks, I'll mess with it again, I got lots of electric fences all around me unfortunately.
Hi Glenn, Many thanks for your detailed reply, I was suspicious it could be SMP related, sometimes it's worse around 9 Mhz but one thing I have no doubt about is that the 10 Kv line is radiating this noise this is why I'm uncertain as to the source…
Hi John, I suppose, thinking about it now I should have tried it via the internal network. I wrongly assumed that msg was an error with the proxy but duh, of course it can't access my kiwi, Thanks again. Mark
Is there a problem with the proxy service ?
Thanks John for your Support, 1 of my Kiwis is working the other will follow soon. Greatly appreciate your help :-)
Thanks for the help John, I appreciate it. I replied to your email, now it says http://emeraldsdr.proxy.kiwisdr.com:8073/ not available connection refused but after reading this thread again there seems to be a problem with the proxy service ? Ma…
Thanks for all the replies guys, very helpful ! :smiley:
Simple you say ? :-)
