Is there a way to change the freq of an autorun WSPR instance?
Thanks! Any help appreciated.
  • I don't believe so...
  • edited January 2022
    the frequency is contained within the kiwi.json file. An adventuresome approach might be to cron a script that swaps that file and then restart the server
  • Thank you for the reply. Given my lack of linux skills, I'll conclude that this is probably for me at least, a hard "no". :-)
    A somewhat related question, given that 22M WSPR transmissions wander around a good bit, is it possible that the WSPR plug in will decode any significantly strong WSPR signal within the passband? (ie, can I adjust the passband out and expect any decodes?)
    I'm aware of the limitations of the existing WSPR plugins, but I do get quite a few 10M decodes with it.
    Thanks again!
    John
  • If I was sure of the right OS level command to restart the server I'd help you more on this. Perhaps John (jks) will weigh in.
  • Rather than restarting the server, maybe John can advise on how to perform the "autorun restart" command from the an OS shell
