smg
- smg
- 1,054
- 36
About Python KiwiClient [Kiwi API question]
Hopefully this helps
The displayed waterfall span at zoom level
zisBW = 30 MHz / 2^z.
Given a centre frequency
cf(in kHz), the visible frequency limits are:BW_kHz = 30000 / (2^zoom) f_low = max(0, cf - BW_kHz/2) f_high = min(30000, cf + BW_kHz/2)
At
zoom=0the Kiwi always shows the full 0–30000 kHz waterfall, regardless ofcf. Forzoom >= 1, the span centres oncf(clamped so you never go below 0 or above 30000 kHz). (KiwiSDR)Example with your numbers
- Command:
SET zoom=0 cf=7550.000000 - Waterfall span: 0–30000 kHz (full band). (KiwiSDR)
- Command:
SET zoom=1 cf=7550.000000 -
BW_kHz = 30000 / 2 = 15000 -
f_low = 7550 − 7500 = 50 kHz -
f_high = 7550 + 7500 = 15050 kHz - So you’ll see 50–15050 kHz.
Why this matches what the Kiwi does
- Zoom levels are power-of-two subdivisions of 30 MHz (e.g., WF7 ≈ 234 kHz, WF8 ≈ 117 kHz), which is exactly 30 MHz / 2^z. (KiwiSDR)
- The waterfall data is 1024 bins wide; bin width is
Δf = BW/1024. Atzoom=0, that’s about 30 kHz/bin. At the max zoom (z=14),Δf ≈ 1.8 Hz/bin. (KiwiSDR) - In the protocol/URLs the frequency values are in kHz (e.g.,
?f=22500for 22.5 MHz), same unit used by thecfyou’re sending. (KiwiSDR) - The Kiwi’s nominal coverage is 0–30 MHz (some installs set 32 MHz), hence the clamping in the formula above. (RTL-SDR, kiwisdr.com)
Mapping bins to frequency (handy for your Java code)
If you index bins
i = 0..1023:Δf = BW_kHz / 1024 bin i spans [ f_low + i*Δf , f_low + (i+1)*Δf ) (in kHz)
That should make your prototype line up perfectly with what the Kiwi sends.
John (Kiwi’s author) explicitly describes the zoom behaviour and bin counts here: https://forum.kiwisdr.com/index.php?p=%2Fdiscussion%2F1472%2Fsetting-dispalyed-bandwidth
- Command:
Antenna switching using IO lines under Web GIU Kiwi SDR
John already has some documentation on antenna switches.
I started making my own code to work with a 3rd party switch
https://github.com/smegoff/RAAS-4-Scripts
Also, check out this thread
https://forum.kiwisdr.com/index.php?p=/discussion/3249/what-antenna-switch
Is my KiwiSDR about to fail?
I've been through a few iterations of Power Supplies, including what I thought was an adequate linear one, that ended up not firing up the Kiwi first time round (using the Kiwi supplied cable too!), and running hot, to settling on this:
https://www.aliexpress.com/item/1005006697287204.html
It runs cool, and seems to meet the demands of the Kiwi with no start up issues at all. I've had it open and its well-made and very clean and uses high quality components.
Not seeing my station in Public [fixed]
LZ1AQ Active Amp and a "Fat" Lazy loop - Dual Opposing Loops.
Found one in the public Kiwi list here
