rrobinet
- rrobinet
- 1,325
- 9
WSPR Autorun Callsigns [info here about GPS antennas & splitters]
Clint has written up an installation blog at: http://ka7oei.blogspot.com/search/label/KiwiSDR
However I have a much updated version of wsprdaemon.sh to release in the next few days which I hope will also simplify installation.
$15 8-way moca splitter works great for me. I got a bag of F to SMA adapters to connect it to the Kiwis. No extra bias-t HW required.
https://smile.amazon.com/BAMF-8-Way-Splitter-Bi-Directional-5-2300MHz -
I bought but have not yet deployed two of the $150 High Sierra Microwave downconverters Jim described http://www.hsmicrowave.com/sdr.html, one for 6M and another for 70cm. They will customize the input frequency and include all the filtering, but you will need to supply a LO. For WSPR a high stability GPSDO LO like the $150 Leo Bodnar would be needed, but for other modes that would be over specced. -
Kiwi Does Indeed Do The Job On WSPR
8 channel Kiwi WSPR decoding script 'kiwiwspr.sh' using Raspberry Pi or other external server
I have attached version kiwiwspr.sh 1.1g which includes a number of significant enhancements. The most important in my judgement is that it now tests the version of wsprd and if wsprd 2.0 is installed it is run with command line flags which will result in 10% more spots from the same captures.
You can obtain that new wsprd by downloading to your Pi the WSJT-x 2.0 release candidate from the WSJT-x web site. I am told we can expect no further ?hanges in the wsprd included in the current RC3 package.
To install this version, download this file to your Pi and rename it to kiwiwsr.sh and then replace your current kiwiwspr.sh with the renamed version.
Verify the version you are running with "./kiwiwspr.sh -V'
