rrobinet
- rrobinet
- 1,325
- 9
wsprdaemon noise graphs
Sorry that I missed the questions in this thread, but I have been dealing with the aftermath of the Northern California extended power outage at KPH.
The optional DEFAULT and following band-specific parameters affect only the noise level and noise graphs. If present, they are comma-separated 'BAND:ADJ" pairs with 'DEFAULT:ADJ' (which should be first) applied to bands for which there is no 'BAND:ADJ' definition.
They are there to allow you to adjust the noise level reports for any gain or loss in the transmission system.
For example, if you have a +20 dB LNA ahead of your Kiwi, then 'DEFAULT:-20' should be added to your Kiwi's receiver definition line. DEFAULT:0 adds 0 dB to your measurements, so it will have no effect on your reported noise levels.
I support band-specific adjustments, since at many (if not most sites) there will be elements in the RF transmission chain which change the gain by frequency.
Get at $50 NanoVNA and check out your rx system from antenna feed point to the Kiwi's SMA input. You may be surprised. -
Fixing broken kiwirecorder installation [fixed now]
that kill line will generate that error printout as it kills itself, but it always kills all other WD tasks before printing the error.
you should have no problem changing conf files as long as you -z with the same conf file as you -a
WD logs to ~/wsprdaemon/watchdog.log. so "tail -f watchdog.log" to see error printouts.
For more logging verbosity, start WD with '-v -a', or for even more '-vv -a'
