- KA7U
- 3,402
- 3
Stu,
You could setup a cron job on the KiwiSDR with crontab -e , see "man crontab" for directions. Examples of commands that would write to the file of your choice below.
KA7Uroot@beaglebone:/home/debian# ct >>temp.log root@beaglebone:/home/debian# cat temp.log 47800 47000 47000 46200 47800 root@beaglebone:/home/debian# date >>temp.log root@beaglebone:/home/debian# cat temp.log 47800 47000 47000 46200 47800 Thu Feb 6 16:29:34 UTC 2020 root@beaglebone:/home/debian# -
New out of box KIWI updating issue. Compiles the same files over and over again. [git fetch issue]
@Tony1951 , I'm sure you removed the SanDisk card after the initial startup? If you didn't, each time the KiwiSDR restarts it will reload from the SanDisk card.
KA7U -
BBG and some PSU problem
QSL Cards
RNZI was kind to send me a couple of email QSL cards!
eQSL web form for RNZI is: https://www.radionz.co.nz/international/qsl/new
Ron - KA7U
Help Needed: How can I access a remoted Kiwi somewhere in 169.254/16 ? [fixed in v1.254]
@n6gn
Glen, you no doubt have this accounted for, but I'll throw it into the mix. When the power comes back up, do you have a switch to prevent a low power start on the KiwiSDR? If the KiwiSDR startup voltage sags, it boots but doesn't complete the load and doesn't initiate the network. It just sits there until the power is recycled to it. So a mountain top needs a power reset switch to the KiwiSDR and probably a charged capacitor to account for initial current draw if the power supply isn't at full power.
Please disregard if this is accounted for.
