36,744
670
  • New GPS Kalman filter results in clearer az/el shadow maps
    Since Christoph's new Kalman filter eliminates GPS outlier solutions the accumulated values from a long running shadow map will be a lot clearer. The az/el shadow map below from the gps tab on the admin page is after about 30 hours of running. You can clearly see that I live in a tall apartment building with a west facing view as everything from 0 to 180 degrees is blocked by the shadow of the building (the antenna is on the metal handrail [ground plane of sorts] of the balcony). The "polar hole" is to the south since I'm in the southern hemisphere and I have mountains to the west.
    Christoph
  • V1.254 - possible bug - No admin screen on iPad Mini [fixed in v1.255]
    Quite right. I thought I had checked the Javascript files for the update. But the usual problem: one has a stray comma that still works in desktop browsers but fails on mobile browsers. Will be fixed in today's update.
    G8JNJ
  • 10ch receiver mode ?
    Absolutely impossible. Because I've run out of cute little icon critters to add to the admin mode page.
    But seriously, I'll look into it..
    WA2ZKDPowernumpty
  • v1.250: 20 kHz bandwidth mode, 10/100 Ethernet speed selection, k/M frequency/passband suffixes
    Three channels at 20 kHz is subject to being reduced to only two depending on experiences with stability. I would have set it at two but I couldn't get the FPGA code to compile using only two channels for reasons I still don't understand. From the CHANGE_LOG file:
    v1.250  December 31, 2018
        Add 20 kHz wide audio bandwidth mode.
            A third entry to the list of FPGA configurations. See admin "mode" tab for details.
        Add Ethernet 10/100 speed select to admin network tab.
            The speed changes after a few seconds of delay (no Kiwi restart required).
            This allows you to be looking at a waterfall in another window and see if
            the Ethernet spurs (if present at your installation) improve or not.
            Be sure the device (router, switch) your Kiwi connects to supports 10 Mbps Ethernet.
        Accept 'k' & 'M' scaling suffixes in frequency and passband parameters.
            Examples: Type "/15k" in frequency box to get a 15 kHz wide passband. Or "/2.7k", "-5k,10k" etc.
            Use a URL of "...?f=7.4M/16.5k" to set a frequency of 7.4 MHz and passband of 16.5 kHz.
            Note uppercase 'M' since 'm' is already keyboard shortcut for mute.
            You can remember this because the 'M' in MHz is always capitalized whereas 'k' in kHz is not.
            Note also 'k' used to be paired with 'j' as the frequency up/down jog shortcut.
            Now use the 'j' and 'i' keys are used (also 'J' and 'I' to jog faster).
            Using the 'i' key is actually more natural because it fits the placement of your
            index and middle fingers better than 'j' and 'k'.
            Finally, 'i' was previously used to select IQ mode. Now use 'q' instead.
            Type 'h' or '?' to see the complete keyboard shortcut help panel.
    elitedataPowernumptynjc
    Powernumptyelitedata
