New GPS Kalman filter results in clearer az/el shadow maps
jksjks
edited January 2019 in Signals Received
Since Christoph's new Kalman filter eliminates GPS outlier solutions the accumulated values from a long running shadow map will be a lot clearer. The az/el shadow map below from the gps tab on the admin page is after about 30 hours of running. You can clearly see that I live in a tall apartment building with a west facing view as everything from 0 to 180 degrees is blocked by the shadow of the building (the antenna is on the metal handrail [ground plane of sorts] of the balcony). The "polar hole" is to the south since I'm in the southern hemisphere and I have mountains to the west.
https://forum.kiwisdr.com/uploads/Uploader/92/3d26ee4e88f826d9a82054c0466fc8.png
Christoph
