36,744
670
  • v1.441: camping fixes, AGC CW threshold, audio FFT extension fixes, misc fixes
    From the CHANGE_LOG file:
    v1.441 March 15, 2021
      Audio camping bug fixes:
        URL redirect now respects URL camp parameter. More work needed for other cases.
        Audio now plays on Safari.
      Added separate CW AGC threshold control.
        Typically a lower AGC threshold is required for very narrow passband settings to
        avoid low sensitivity. Since narrow passbands are most often associated with the
        CW/CWN modes it was decided to add a separate AGC threshold control active only in
        those modes. The original threshold control applies to all other modes.
        The two are stored in their own separate browser cookies.
      Fixed bugs in the Audio FFT display (the one that appears in 8-channel mode when more
      than two channels are busy, or if the URL "no_wf" parameter is given):
        The LSB passband is drawn in the same place as the actual FTT output.
        The FFT display bins were flipped to be correct (i.e. low vs high frequency).
        Autoscale mode works better than before.
      Disabled compression ("comp") button in DRM/SAS/QAM modes since it has no meaning
        and effect in these modes.
      Fixed shift-click in SWBC bands not selecting nearest 5 kHz boundary.
      Fix long audio latency on browsers that display "Click to start OpenWebRX" overlay.
    rz3dvpChrisSmolinskiPowernumptyHB9TMCnjcbenson
  • v1.440: C-QUAM & channel queueing/camping
    v1.439,440 March 14, 2021
      Channel queuing and camping:
        When all the Kiwi channels are busy(*) it is now possible to enter a queue to wait
        for the next available channel. The queue is FIFO and multiple parties can
        occupy the queue (your queue order will be shown).
        If all channels are busy you can also now "camp" on an existing connection and
        hear the audio of that channel. The only adjustment is to change the audio volume.
        Otherwise you experience all the changes performed by the owner of the channel
        (tuning, mode, etc).
        You can also be in the queue waiting for your own channel while camping.
        It is possible to use camping even if free channels are available by connecting
        using the URL parameter "camp", e.g. my_kiwi:8073/?camp
        You might want to do this if you know there is already a connection you want to
        camp on, but there are also free channels you don't want to unnecessarily occupy.
        In theory camping requires only slightly more resources because the audio stream
        is simply being duplicated and sent to the camper's network connection.
        The Kiwi admin can configure the maximum number of campers allowed, including zero.
        Later on we can look at adding audio-related features to camping that only require
        browser/javascript resources, hence place no additional load on the Kiwi server
        (e.g. S-meter, recording, audio FFT waterfall/spectrum display).
        These changes are complex and will no doubt have bugs and corner cases to fix.
        (*) or unavailable due to password protection on those Kiwis that have split
        public/private channels.
      Added C-QUAM AM stereo mode to SAM mode button which now cycles as: SAM/SAL/SAU/SAS/QAM
        Based on the work of Github user MaPePeR, see: github.com/jks-prv/Beagle_SDR_GPS/issues/395
        Remember that alt-click will toggle the mode buttons backwards, e.g.
        alt-click on SAM wraps back to QAM (faster than clicking forward on SAM 4 times).
        The same applies to the keyboard shortcut: shift-A is SAM mode forward to SAL
        alt-shift-A is SAM backward to QAM.
      Apply ITU region selection to band display (e.g. 40m ham band now stops at 7.2M for R1)
        It is possible this change will cause problems if extensive customization of
        the kiwi.config/config.js file has been made by the user. Please let us know if
        this happens to you.
    rz3dvpPowernumptyChrisSmolinskilinkfanelnjc
  • v1.352: new time station extension (timecode decoder)
    v1.433 February 12, 2021
      Timecode extension improvements:
        Support for JJY(Japan), RBU(Moscow), RTZ(Irkutsk), BPC(China) added.
        While running AGC delay is temporarily increased to improve noise immunity.
    rz3dvpcathalferrisKA7U
  • RSDN-20 beacons reactivated on 11.9, 12.65 & 14.9KHz
    Feb 2021: Alpha "Khabarovsk" (nearest town Elban) as received from the Kiwi in Khabarovsk about 200 km distant. MSK signals VTX3 India and NWC Australia also present.
    cathalferris
  • New KiwiSDR forum: differences and features
    Okay, after way too much effort I think attachment links are working again. There were 584 such attachments in the database and I have been spot checking the comments containing them. If you notice anything amiss please let me know.
    WA2ZKDjohnk5mo
