- jks
- 36,720
- 670
Recommended routers?
web file modifications (CSS/JS)
Awesome!
Wrap that stuff in a <style> ... </style> and chuck it in the box at the bottom of the webpage tab of the admin page that says "Additional HTML/Javascript for HTML element (e.g. Google analytics)". Then you don't have to edit any files and the changes will persist across software updates. And it's easier to experiment with. No need to restart the Kiwi or anything. Just edit the stuff in the box and reload the user connection to see the result. Edits in the box are saved to the Kiwi configuration as you type each time you press the return key (arguably a bug).
i.e.@media only screen and (max-device-width: 600px) { #id-readme { display: none; } #id-control { transform: scale(.8); transform-origin: bottom right; right:0 !important } div#id-top-bar * { font-size: 0.9em; } #id-band-container { display: none; } } -
Awesome!
kiwirecorder noise [fixed]
Noiseblanker for kiwirecorder [fixed]
