- jks
- 36,228
- 639
        Private use of a KiwiSDR receiver in France
        Reflashing BBB with Kiwi-1 with image v1.682 [fixed]Believe it or not, this was probably a power supply problem. We've seen over the years that writing SD cards requires a substantial amount of extra peak current. So a power supply that operates a Beagle + Kiwi board normally may not also be able to power an SD write operation on top of that. This explains why running a Beagle + SD write alone (without the Kiwi board) worked. The current saved from not having the Kiwi board was enough to handle the SD write peak currents. I have updated the operating guide instructions to mention this issue.
        v1.683
        v1.683From the CHANGE_LOG file: v1.683 May 30, 2024 Antenna switch: Fixed problems with Arduino Netshield backend script. (thanks N8OOU) CAT interface: Removed newline characters (\r\n) from end of each transmitted CAT string because it was reported to cause problems with some CAT software. (thanks DF6DBF) DX community database: UNID FSK signal at 61.84 is Inskip GBR. (thanks HB9TMC) Added entries to satellite table for Galileo gsat0227 and gsat0225 launched 2024-04-28 and currently under commissioning. (thanks F4FPR) We have now formally purchased a license to use the Kiwi logo from Hayes Roberts at bluebison.net. Previously we had an informal agreement with Hayes where he allowed us to use the logo provided we always included the domain text "bluebison.net" wherever the logo was used. By purchasing a licence we can now remove the text and make uses of the logo look a bit cleaner. Big thanks to Hayes for giving the KiwiSDR its logo identity recognized by SDR enthusiasts around the world.
        stupid gps question/idea [good idea actually: 10 MHz ref output]
