36,723
670
  • Extension of the antenna switch for direct execution of shell scripts on the Kiwi
    The way the code is currently, if you use a "%20" that gets translated into a space character in the Kiwi configuration itself, which is no good.
    What I've done is made the "+" character get translated into a space. This is a URL standard and compatible with the fact that the field is being interpreted as a curl URL argument. An actual space character is used to separate multiple curl commands as it is now for backward compatibility.
    jimjackii
    Ugh. I don't understand. That code doesn't work at all. I tested it with Glenn's V/UHF converter and it worked fine. I'm sure of it. But looking at it now there's no way. It does everything wrong.
    Give me a bit to fix it. I'll have it for the next release. Embedded spaces, default antenna mode and all..
    jimjackii
  • 24 MHz SPI Clock - disadvantages?
    The waterfall(s) may run slower. Depending on the total number of connections.
    HB9TMC
  • New product accessories in our store: SDR protection circuit, MW filter
    I didn't design these. Ask sales@kiwisdr.nz
    Nate_R
  • v1.803
    From the CHANGE_LOG file:
    v1.803 February 14, 2025
      Added admin password reset scheme. See KiwiSDR forum for discussion.
      Iframe extension
        Show all 16 instances in user extension menu. (thanks VK3KHZ)
        Prevent duplicate menu names from being setup. (thanks Steffen)
      SSTV extension
        Added support for modes:
          PD: PD120 (used by ISS) PD160 PD180 PD240 (but not PD290)
          Robot: R12
          Wraase: SC60
          Pasokon: P3 P5 P7
          FAX480
      Fixed bug preventing proxy client start if not running in certain situations.
    HB9TMCTremolatnitroengineG4ZFEjimjackii
