smg
- smg
- 1,009
- 36
https://forum.kiwisdr.com/index.php?p=/discussion/comment/21127#Comment_21127 That certainly does make your device a target. Are you using a firewall or router?
https://forum.kiwisdr.com/index.php?p=/discussion/comment/21124#Comment_21124 Are you direct connected to the internet and not via a proxy?
https://forum.kiwisdr.com/index.php?p=/discussion/comment/21114#Comment_21114 I only use a paid for version of ChatGPT - and use it for some daily tasks like writing SQL queries, some dirty python, HTML etc, and reviewing texts, all the stuff I don'…
Not sure how you feel about this, however I watched an interesting video on it. https://www.flux.ai/p https://www.youtube.com/watch?v=vvURxAfMPT0
The only computer near it is a mac mini (M2) in a room at the rear of the garage, and in the garage is my proxmox cluster. Interesting that this is quite new and all the other devices have been in the garage for some time. The cabinets are all eart…
Well it must be something local, as another Kiwi not far from me isn't receiving them.
Seems to be across much of the HF Band https://forum.kiwisdr.com/uploads/935/OIFIQKIW8YA1.png
I settled on the cheaper one. the difference is the manufacturer of the transformer. In this case I dont think it matters too much.
I've been through a few iterations of Power Supplies, including what I thought was an adequate linear one, that ended up not firing up the Kiwi first time round (using the Kiwi supplied cable too!), and running hot, to settling on this: https://www.…
Its stopped now. It looks like a cheap sine wave inverter - as I've had this before running one at home........... not pure sine wave, pure evil.
https://forum.kiwisdr.com/uploads/666/9XT77RI285V0.png
I get them loud and clear down here in NZ too.
So i have made some more changes to my script. LOL https://forum.kiwisdr.com/uploads/619/P6PCGYUTOO74.png If anyone wants it, they are welcome to it. Its just a python script. The benefit is that unlike the blackcat logger, this one doesnt clear the…
I believe mine is logging OK. I re-jigged the python script to plot the bands in the SNR data https://forum.kiwisdr.com/uploads/316/HJ507ZWGT51P.png
https://forum.kiwisdr.com/index.php?p=/discussion/comment/21048#Comment_21048 On the other hand, the spirit of the hobby is, as you say, experimentation too. I know that I am a purist when it comes to buying something and using it. Like, as it came …
I had a tinker with it just after Tech Minds published his video on it. Has potential and looking forward to seeing it develop! :-)
You could try reaching out to Jeff Geerling. His "new" hobby is time and has a number of videos on it. Hes also a HAM, his Dad is a radio / RF engineer, and a massive open source developer and may already have a solution, or would be quit…
https://forum.kiwisdr.com/index.php?p=/discussion/comment/21019#Comment_21019 Well if anyone knows python, they are welcome to make this good :-)
An SNR graph into the admin page? :-D I have been using blackcats SNR logger, however it always clears the graph when the kiwi restart for any reason - like an update etc. So I tried a little Python and some AI help to write this monstrosity! :-D It…
https://forum.kiwisdr.com/index.php?p=/discussion/comment/20998#Comment_20998 You won't get away from the noise like that with a loop antenna. I did this and it was terrible. The benefit of the loop is you will null noise depending on where you hav…
I have a similar issue (bearing in mind this is mid-Sunday morning here and QRM is at its finest. ;-) https://forum.kiwisdr.com/uploads/532/VECNO7QPC2EU.jpg However, from later in the evening though to 6am it's quite clean and bearable. However, as …
You will definitely need to put that regulator on a decent heat sink running the kiwi 24/7. I just bought one of these: https://www.aliexpress.com/item/1005006697287204.html Most excellent for the price. Very clean. Runs cool.
I find this an interesting (almost) paradox. On one hand, we have the KiwiSDR, designed to be an all-in-one, simple to use out-of-the-box solution, and on the other, the antenna, which needs to be carefully considered, with real science applied to e…
https://forum.kiwisdr.com/index.php?p=/discussion/comment/20937#Comment_20937 /gets credit card out.............
We run a WISP network here and use CGNAT - however if a customer wishes to run any services, we add $10/mth to their bill and give them a static IPv4 address It wasnt Minecraft servers that was the issue - it was the warez servers we stood up ;-)
