o00scorpion00o
Thanks, I see the donate button. I will have to do something like this.
What do people think about installing the setup in a pump house for well ? It will be easier than installing cables in the attic, but I may end up going to the attic. Not sure yet.
The Antenna will be the Bonito FX 10 Meter Loop.
- o00scorpion00o
- 358
- ReadOnly
- 17
Thanks, yes I did try another browser on my work laptop, probably should have done this first but I was not having issues at home in chrome nor on the work laptop until yesterday but there's always win 10 updates and you never know if one might scre…
The Issue seems to be with Chrome, at least on my work laptop. Working fine on Edge.
Ok I should have done this before but I tried on my Iphone X and it's working no problem. Could be a Microsoft issue then alright ? that would not be a surprise. But unfortunately Apple will not allow you to stream Audio from a browser with the scr…
http://emeraldsdr.ddns.net:8073/ check out the above link to my SDR and see the issue, it seems to be common on many sdr's , it's not just mine. I notice this when I'm at home and in work connected to my own network connecting to other SDRs and in …
I've noticed this on other Kiwi SDR's too since the last update or two and sometimes a refresh or two fixes it but it's most annoying on mine, nothing solves it. i'll try a reboot.
The problem here is that Apple will not allow streaming once the screen is locked. This is why there needs to be an app, the most user friendly web interface still will not allow streaming audio once the screen is locked.
Haha yeah I know the feeling, "Na, something as simple as a reboot couldn't fix it ? " haha.
Ok, reboot did the trick, thanks again, never happened before, saved me a lot of hassle ! :-)
Thanks for the reply. I tried a different browser with the same result, I'll try a good O'l fashioned reboot in a while.
Won't the boni whip work on the 5 v batteries that power cell phones ? They are plenty. I just power my Bonito FX from the USB port on the Kiwisdr. Saves needing another supply. I found contacting the seller Sep_Store on eBay quiet simple, it mig…
Hi Gary. I just emailed him what I wanted. 5v 2.5 amp and 12v 3 amp linear supply and whatever size plugs you need. If you can think of anything else that would benefit from changing to linear then do it at the same time.
Found some more RFI interference, A satellite receiver switch mode power supply, I was picking it up on the MW band, I've it currently switched off but I'll have to switch it on again later. At least it's an external power supply and I can get anot…
Thanks JKS, The carrier on 25967 is a baby monitor..... :-) Trying to find alternative monitor.
Ah, It just accepted my latest attempt, phew ! Thanks for the help.
Thanks for the reply, Hmm, I have tried a couple of combinations but it doesn't seem to accept it as a valid callsign.
There would be far less noise in the pump house than the attic I'd say. I can also go to the shed because I'll be using a mobile broadband device so can technically install it anywhere I get power.
Thanks, I see the donate button. I will have to do something like this. What do people think about installing the setup in a pump house for well ? It will be easier than installing cables in the attic, but I may end up going to the attic. Not sure y…
Thanks, that's quiet a chunk of data but I suppose they would't be in use all the time. Has anyone added a donation to their sdr site ? and has anyone donated ? that could be really helpful.
"Someday the admin interface might even show statistics graphs of the bandwidth consumed." Yes that would be very useful. Does anyone know on average what their setup is consuming ? I fear the 20 GB I would have would be way too little. …
