G8JNJ
- G8JNJ
- 4,628
- 127
I'd suggest checking your power supply, as an initial part of any investigation.. I've had similar problems, and it's nearly always turned out to be power supply related. On particular problem is poor quality electrolytic capacitors that "dry&q…
https://en.wikipedia.org/wiki/Alpha_(navigation) http://www.vlf.it/alphatrond/alpha.htm
Sorry, this makes no sense to me when run through Google translate, and I suspect it is spam. Discussions on this forum tend to be in English, and posting in English will give you a better chance of receiving any replies. Regards, Martin
The tuning steps default to +/- 5kHz above 7200kHz in some regions, where there is no amateur allocation above that frequency and it remains a Broadcast only allocation. Regards, Martin
Ignore my ramblings, I forgot I normally have the waterfall tab open, Doh... In my defence, it's getting late. Regards, Martin
Hi John, I still use the mono colour option most of the time, in conjunction with the peak hold function. I wonder how many folks actually use the spectrum display ? I tend to have it on all of the time, but I think I may be in the minority, and giv…
Yes, I think 1 & 6 connected alone, should be loops A & B I believe you have 4 & 6 transposed on S1 in your switch diagram Regards, Martin
To be honest, if you live in an urban area, and have the ability to do so, then the best results will be obtained by moving the KiWi to an electrically quiet location. The ITU noise curves, and my own experience, indicate that you will obtain 10 to…
Broadband loops don't have to be mounted that high above the ground. 2m is about the optimum, and my loops are actually ground mounted in among some bushes. The key thing is to get them as far away as possible from potential noise sources. They don'…
Hi, Yes, for a single loop connected as "A" connect pins 3 & 6 together. You don't need to use V1, V2 & Ground for a loop, those are only required if you wish to use a separate pair of dipole elements. BTW The thing that catches ma…
I understand the reasoning behind this, but I'm slightly concerned that it may further discourage owners from bothering to install and use the GNSS antenna. This could in turn reduce the number of KiWi's available for things like TDoA runs. It could…
Same here. I posted a review of the orignal KiWi on eHam several years ago, but I recently noticed that the whole set of existing KiWi reviews had disappeared. I don't know if the eHam reviews get automatically purged after a number of years, but th…
Hi Serge, I suspect that for some reason, the KiWi I/Q Balance needs to be reset. I think you can only do this via the I/Q extension on a KiWi that is on the same local network as your browser, as you need to disconnect the antenna whilst you perfor…
Don't buy the Bonito loop. Have a look at the Loop Antennas IO group. https://groups.io/g/loopantennas You will find some familiar names on there, and one or two, are offering ready built loop amplifier PCB's based on Wellbrook and LZ1AQ's designs. …
Looks like it was a browser issue. Clearing cookies resolved it. Thanks, Martin
"Many thanks, there seems to be so much to look at with so many tabs on the admin page." There are so many user cases that it's difficult to cater for everyone. But the more you use your KiWi, the more thankful you will become that a speci…
You only need sufficient attenuation to take the strongest broadcast stations down by just enough to prevent ADC overloads from occurring. I generally try to keep all signals across the 0-30MHz spectrum below -30dB. If you have an existing band stop…
It is a good idea to set an inactivity time limit. Otherwise, you will have people connect, and then leave their browser connected, even if they are not actively using the KiWi, and this prevents others from using one of the receivers. I generally s…
Generally speaking, you are better off using WiFi if you can get it to work. Unscreened twisted pair is often better than screened twisted pair, as it doesn't provide an additional ground path. I tend to wrap my Ethernet cables with about 12 turns, …
The key element of the KiWi is the software and after sales support that John provides free of charge, which unfortunately has been utilised by various competitors, to produce and sell "cheaper" products. This undercutting erodes John's p…
Hi Frank, That looks clean, and the distribution of noise looks to be correct. The fun starts when you connect your antenna, mainly because of introducing other conducted paths for noise to ingress. As a further test, connect just the ground from yo…
I have said this before, but I consider the KiWi to probably be the best radio hobby related purchases I've ever made, and it has reinvigorated my interest in Short Wave listening, and utility monitoring. Nearly every week I discover something new, …
I'd be tempted to have a chat with your neighbour, mine have always been interested in finding out what could be causing such interference, but perhaps I'm lucky that many of them seem to be ex-engineers. As previously mentioned, it's most likely a …
In addition. If you have more than the specified number of users trying to connect, the additional ones can "queue" to wait for the next free slot, or "camp" where they can "piggyback" onto an existing user and hear jus…
You will have additional aliased noise contribution from the LNA, which is another reason for the 40MHz LPF. Regards, Martin
You can place attenuation ahead of an LNA to improve strong signal handling, but the amount of attenuation needs to be chosen carefully, to take into account the LNA gain and Noise Figure, in order to ensure that the overall system Noise Figure is n…
Ideally, you should place attenuators between the LNA and receiver, this ensures the best overall Noise Figure. However, there is a trade in LNA design between strong signal handling and Noise Figure. Most cheap LNA's don't have a sufficiently good …
Personally, I think the internal attenuator is more trouble than it is worth. An external attenuator controlled by the KiWi, as a separate accessory, may be a better option for those that need to handle day / night propagation changes. However, in …
