G8JNJ
- G8JNJ
- 4,661
- 130
If you are using a T2FD at low height, you may possibly benefit from an LNA. A lot depends on your local circumstances and level of background noise and interference. The KiWi has a noise figure of around 14dB (from memory), which by itself is just …
It depends, but generally I'd say no, you will most likely only boost both the wanted and unwanted signals, so the overall Signal to Noise ratio will remain the same. However, you will eat away at the KiWi's available dynamic range, and most likely…
Hi Chris, I find the inactivity timeout to be the most useful, and very rarely have to block frequencies. Although when I have been forced to do so, it only seems to be required a few days. The timeout requires some user interaction to maintain a se…
I'd like this too please, as I always run with the RF spectrum display on as default. Regards, Martin
As a temporary measure, just try adding say 3dB attenuation, or just enough to stop the red OVE indicator from flashing. I don't think you will need that much attenuation to improve things significantly. Regards, Martin
I'd still suspect the power supply & cable. I found that my KiWi's were more reliable if fed with 5.4V at the barrel connector when under load. A slight voltage drop across the KiWi board results in 5V at the Beagle header. The voltage drop on…
OK, thanks John. Regards, Martin
Hi John, I've not been having much luck with TDoA runs over the past few days. Every time I seem to get "Protocol Error" message. Although after a while the map showing the results does finally appear. In addition, half way though even sho…
Did the problem occur after you split the Longwire antenna ? It may simply be that the RF levels have changed, due to a different matching arrangement, or propagation has altered, driving the KiWi into Overload. Regards, Martin
Hi Trevor, I don't think you need a filter, you have more than enough gain ahead of the KiWi, that allows you to simply add broadband attenuation. You don't need massively strong signals to achieve good reception, you just need to get the balance r…
https://forum.kiwisdr.com/index.php?p=/discussion/comment/21535#Comment_21535 Your attenuator is currently set at 5dB, ideally you could do with a bit more. If you look at a quieter section of the MW broadcast band, where there are very few actual s…
Hi Trevor, I don't think your situation is quite as bad as you think it is. I'd suggest sorting out the main issue first. Your loop is providing quite high signal levels, and the two strong medium wave stations on 693 & 1053kHz are almost certai…
Hi, Can you tell us where you are located, and what type of space and environment you have available for antennas, as this will define what you can receive. My Wessex SDR's, located on a hilltop in the SW of the UK, have exceptional reception, and I…
Can you manually set up port forwarding on your router, to allow external connections ? Regards, Martin
No, a lot of the interference you have is being radiated by the noise source itself, and received via your antenna. I commented on the various ones I could identify in a previous thread. https://forum.kiwisdr.com/index.php?p=/discussion/3666 Regards…
Linear supplies tend to be quieter than switched mode supplies. But they can generate some noise. The biggest problem is often that they can introduce an additional noise route via the mains earth, which may not happen with small switched mode units…
It depends... If the Apple charger is actually contributing noise in the first place, but it may not be. There are so many potential noise sources, in, and around the home, that it may not be possible to observe any difference if you swap out the Ap…
The noise centred around 500kHz, with narrowly spaced carriers, is from a switched mode power supply You have occasional intermodulation products around 99 & 332kHz when the ADC is being overloaded and the Red OV indicator is flashing. Currently…
OK found it http://lowestoft.proxy.kiwisdr.com:8073/ The rapidly pulsing interference is from one or more Ethernet data over mains powerline adaptors. The noise band from approx 8.5 to 12MHz is VDSL Upstream frequency band U2 I'm not sure what the n…
Can you provide a link to your KiWi ?
I use old style 12V 3A or 5A Linear CB power supplies, often available cheap at car boot sales or radio rallies etc.
I seem to vaguely remember that VARA HF modem has a test / setup mode that generates sweeps. However, I can't find an example, so I may be wrong. Regards, Martin
If it is really 6765 USB, it's most likely Bangkok meteo FAX. If it is 7150 LSB it's most likely one of the many, and increasingly difficult to identify, Amateur data modes. Regards, Martin
Unlikely. With reception, it is not about obtaining the strongest signals, but maximising the Signal To Noise Ratio. A lower height in a different position may work better. Once you get above a certain height above the ground reference, you may star…
You don't mention the size of the loop you intend to use, but in most cases it will require a balanced amplifier (or an unbalanced amplifier and a balun), with a low noise figure and about 20dB gain, to provide a sufficient degree of sensitivity for…
I agree that the SNR measurement function is flawed, and appreciate that you, John, may have spent more time on it than you would like. However, even in its current form it is far better than having nothing at all. This is especially true when using…
Ah OK, however it would be interesting to see if John's filter, also responds to broadband noise that looks like VDSL. I wonder if there are several consecutive FFT bins, that contain the same level, could this be interpreted as wideband noise rathe…
The most obvious one is http://zl4md.proxy.kiwisdr.com:8073/ It is consistently near the top of the SNR leaderboard, but has a massive block of noise from 8.5 to 12MHz In the UK, but already poor SNR http://21246.proxy.kiwisdr.com:8073/ http://remo…
It's difficult to provide any advice or assistance, based on your description alone. Maybe provide a link to your KiWi, so that we can listen for ourselves ? Regards, Martin
Oh dear, that's odd, as your Overload indicator is flashing too, despite there being no signals evident. http://w3ilt.proxy.kiwisdr.com:8073/ Good luck, Martin
