smg
- smg
- 1,008
- 36
Sitting my Ham license :-)
Apexradio 303wa-2 vs MLA30+ (Genuine)
LZ1AQ Active Amp and a "Fat" Lazy loop - Dual Opposing Loops.
Not to sure
you are welcome to look at mine.
You might find asking in the Loop Antennas group over at https://groups.io/g/loopantennas
So, some really un-scientific anecdotal evidence (listening and comparing RSSI / S-Meter levels on various stations, including UTC, 20Mtr HAM, various broadcast bands, its a tight race. The MLA 30 gives a few DB more signal, however I have the gain turned up on it. The Apex whip has an inline galvanic isolation transformer on it, and the noise floor between them both is almost indistinguishable.
I'm quite amazed at the apex 303, and the fact it is a short whip totally passive.
Time to get an antenna switch.
Impressive!
Antenna switching using IO lines under Web GIU Kiwi SDR
John already has some documentation on antenna switches.
I started making my own code to work with a 3rd party switch
https://github.com/smegoff/RAAS-4-Scripts
Also, check out this thread
https://forum.kiwisdr.com/index.php?p=/discussion/3249/what-antenna-switch
About Python KiwiClient [Kiwi API question]
Hopefully this helps
The displayed waterfall span at zoom level
zisBW = 30 MHz / 2^z.
Given a centre frequency
cf(in kHz), the visible frequency limits are:BW_kHz = 30000 / (2^zoom) f_low = max(0, cf - BW_kHz/2) f_high = min(30000, cf + BW_kHz/2)
At
zoom=0the Kiwi always shows the full 0–30000 kHz waterfall, regardless ofcf. Forzoom >= 1, the span centres oncf(clamped so you never go below 0 or above 30000 kHz). (KiwiSDR)Example with your numbers
- Command:
SET zoom=0 cf=7550.000000 - Waterfall span: 0–30000 kHz (full band). (KiwiSDR)
- Command:
SET zoom=1 cf=7550.000000 -
BW_kHz = 30000 / 2 = 15000 -
f_low = 7550 − 7500 = 50 kHz -
f_high = 7550 + 7500 = 15050 kHz - So you’ll see 50–15050 kHz.
Why this matches what the Kiwi does
- Zoom levels are power-of-two subdivisions of 30 MHz (e.g., WF7 ≈ 234 kHz, WF8 ≈ 117 kHz), which is exactly 30 MHz / 2^z. (KiwiSDR)
- The waterfall data is 1024 bins wide; bin width is
Δf = BW/1024. Atzoom=0, that’s about 30 kHz/bin. At the max zoom (z=14),Δf ≈ 1.8 Hz/bin. (KiwiSDR) - In the protocol/URLs the frequency values are in kHz (e.g.,
?f=22500for 22.5 MHz), same unit used by thecfyou’re sending. (KiwiSDR) - The Kiwi’s nominal coverage is 0–30 MHz (some installs set 32 MHz), hence the clamping in the formula above. (RTL-SDR, kiwisdr.com)
Mapping bins to frequency (handy for your Java code)
If you index bins
i = 0..1023:Δf = BW_kHz / 1024 bin i spans [ f_low + i*Δf , f_low + (i+1)*Δf ) (in kHz)
That should make your prototype line up perfectly with what the Kiwi sends.
John (Kiwi’s author) explicitly describes the zoom behaviour and bin counts here: https://forum.kiwisdr.com/index.php?p=%2Fdiscussion%2F1472%2Fsetting-dispalyed-bandwidth
- Command:
New Signal - What could it be?
Is my KiwiSDR about to fail?
I've been through a few iterations of Power Supplies, including what I thought was an adequate linear one, that ended up not firing up the Kiwi first time round (using the Kiwi supplied cable too!), and running hot, to settling on this:
https://www.aliexpress.com/item/1005006697287204.html
It runs cool, and seems to meet the demands of the Kiwi with no start up issues at all. I've had it open and its well-made and very clean and uses high quality components.
