- KA7U
- 3,402
- 3
How to connect via wifi
The search box in the blue title bar will find lots on the topic. Try wifi kiwisdr in that search.
This post might be quite useful to you: http://forum.kiwisdr.com/index.php?p=/discussion/comment/9270#… (more)
first fan died... how long do these things last- what other cooling alternatives ?
Two of my KiwiSDR units lost the fans finally. So I took them out, blew out the bugs, and put them back together without the fans. Set the two units on edge, with one end elevated 1 1/2" by using a… (more)
Nick,
I think 10mbits will run the KiwiSDR. I applied the ethtool utility with your parameters to my KiwiSDR's. The first one was imperceptible change, then the 2nd one showed improvement on the… (more) -
Wellgood balanced loop amplifier, (Wellbrook clone).
I have the first Wellgood LNA online @ ;ka7u.no-ip.org:8074 . It is using a 120cm loop made out of 1" (25mm) soft drawn copper pipe. One of the transistors is running hot and might not last… (more) -
Stu,
You could setup a cron job on the KiwiSDR with crontab -e , see "man crontab" for directions. Examples of commands that would write to the file of your choice below.
KA7Uroot@beaglebone:/home/
… (more) -
DRM Heard
15325KHz Voice of Russia GRFC loud and clear at grid DN14lf. I was able to decode on all antennas. This video is testing the KiwiSDR using the BeagleBone AI in 4 channel mode. All 4 channels were in… (more) -
New out of box KIWI updating issue. Compiles the same files over and over again. [git fetch issue]
@Tony1951 , I'm sure you removed the SanDisk card after the initial startup? If you didn't, each time the KiwiSDR restarts it will reload from the SanDisk card.
KA7U -
BBG and some PSU problem
I put these in service on my KiwiSDRs and today the power company had on and off conditions for awhile. I set the time on for a 90 second delay. All the boards came up 90 seconds after the power and… (more) -
