36,739
670
  • Antenna switch | Kits | Commercially available?
    What happened to your previous script? It was much closer to being correct. That vibe thing is crap.
    Your AntSW_ShowBackend function needs to return info in the exact format as shown below (example from the beagle-gpio backend). A version number as second parameter is missing. The number of channels 3rd parameter is missing the "ch" directly after the number. A "mix" or "nomix" 4th parameter needs to indicate if the switch can mix antenna selections.
    Get rid of that case ... esac stuff at the end.
    AntSW_ShowBackend() {
      echo "beagle-gpio v2.0 10ch mix not-applicable"
    smg
  • missing samples [not just a Kiwi problem]
    This has been a problem in the past, but is not known to be an issue currently.
    The most sensitive test of dropped samples is to run the FAX extension. The slightest dropped sample will cause the image to become progressively more shifted (i.e. lines looking broken) as the image rendering proceeds. I tried this just now on several Kiwi running the most recent software version and all seemed well. An example image is below. All those lines should not have any offsets or breaks. The 400 pixel tall FAX viewport at 120 LPM represents 3.33 min of reception. So no dropped samples over that time period.
    Have you tried different browsers? One factor in the audio is that the browser's scheduling of the Javascript audio processing must not have any realtime performance hits. Otherwise samples can be lost. But that's a browser problem not a Kiwi problem.
    The audio and waterfall use completely different mechanisms and so any glitching should not be correlated. If they are that may point to network issues.
    okron
  • Is my KiwiSDR about to fail?
    Yes, it is possible the Ethernet on the Beagle is beginning to fail. Specifically the Ethernet PHY chip. There was trouble with this some years ago that seemed to be a bad batch of PHY chips, although this was never conclusively proven.
    You could consider replacing the Beagle with a new Seeed BeagleBone Green. Roughly $50 USD + VAT. Be careful not to use any other Beagle type. Specifically not the Seeed BeagleBone Green Wireless. It is not physically compatible with the Kiwi board. If you can find the older BeagleBone Black that will work also. But make sure it is a "rev C" board that has 4 GB eMMC (not 2 GB).
    alain_
  • SNR Measurement Issue, Perhaps? [fixed in v1.811]
    Okay, I fixed this. Wasn't too bad. Will be in the next release.
    Will allow any future internal extensions that use the waterfall to work also (currently our WSPR and FT8 internal extensions only use the audio stream).
    va3rom
    If it's really only two characters it might be that operating at 9600 baud will be okay. You'd just have to try it and see what happens as far as any realtime impact.
    smg
  • v1.810
    From the CHANGE_LOG file:
    v1.810 May 15, 2025
      Admin interface (desktop):
        Type "h" or "?" to see a help panel for the admin page.
        Keyboard shortcuts: Tired of reaching for the mouse or trackpad to select a new tab in the
        admin navigation bar? Now just type the beginning character of a tab name to switch to it,
        e.g. 'd' for the DX tab. If more than one tab is matched they will cycle left-to-right e.g.
        's' selects between "Status" and "Security". Typing a capital letter cycles right-to-left.
        The left/right keys also works. On the extensions tab the up/down arrow keys cycle the
        extension menu on the left side. There is a quirk related to the console tab described in
        the help panel.
      Fixed bug that broke "retain focus" mode of certain input fields. Like the "DX label filter"
      accessed from the "@" shortcut key. When you make an entry in the "ident" or "notes" field
      those entries are supposed to remain selected so that you can make subsequent entries without
      have to reselect the field (e.g. by clicking on it). Same for the "freq/ident/notes" fields
      on the admin page "DX" tab. I'm surprised no one complained about this!
      Fixed ALE extension processing of URL parameters. (thanks DK9FI)
    G4ZFE
  • Antenna switching - Waterfall auto scale [fixed in v1.811]
    I checked the code, and I had added something. But in looking at it I see what I did wasn't quite right.
    So I have something now that I think will work. Will be in the next release..
    jimjackii
  • This is why we can't have nice things
    I have the web server log and that's all I need. tcpdump when anything more specific required.
    I'm not going to continue talking about this since we don't know who's reading the forum.
    smg
    Not following this in detail because I'm so busy. But try and run this at 115k baud at least to avoid impacting the Kiwi realtime performance (i.e. causing the audio to break). That was my experience when I added the CAT output option that also used /dev/ttyUSB0 (and /dev/ttyASB0 if necessary).
    smg
  • VDSL2 interference what options have I got
    There was a discussion about this recently over on the wsprdaemon forum: groups.io/g/wsprdaemon/topic/vlsl_telecom_network/112581272?dir=asc
    I've told this story before but will repeat it in case anyone has self-interference problems.
    Before my apartment building was wired for fiber (FTTP) all we had was VDSL2 from a pedestal on the street over the crappy building CAT3 telephone cable. I had some noise, even after adding some toroids, around -95 to -100 dBm (uncalibrated) as shown in the first image. Not too bad.
    One day one of the VDSL band segments jumped up almost 15 dB in signal strength. I looked at the VDSL statistics page on the modem and the "downstream" transmit power from the line card in the pedestal was at +14 dBm compared to the usual +3 dBm, which is what the statistics page said my modem was transmitting in the "upstream" direction. They were always about equal in the past.
    After resetting the modem there was of course a VDSL retrain cycle and the downstream power dropped again to +3 dBm. I happened to catch this on the waterfall in the last image. Not quite as good as what I had before. But a big improvement.
    FrankinAu
