Connecting Kiwi via WiFi
                    At home, no problem to use Ethernet to connect to my router.
Away from hone (motels, vacation rentals, DXpeditions) there is often no access to the router.
To solve that, I;ve been using an AP in bridge configuration, or a laptop with bridgee mode configured in Win 10.
What would be even better is to have WiFi in the Kiwi ?
Is there anything in motion to do that? Failing that, is there any way to add WiFi to the Kiwi, possibly via a USB dongle? Or other methods?
Chuck
Chuck
I have experienced reducing/removing the feed line as greatly improving common mode noise on a kiwi. A wifi dongle, located right at the kiwi which is also right near the antenna combined with a very-carefully decoupled power source, possibly a battery also located right at the kiwi, can greatly reduce the possibility for noise contributions and has shown to make a very considerable difference in overall sensitivity.
I have one kiwi 'package, with battery, wifi dongle a small (active) dipole antenna all mounted together within 50 cm of each other and light enough to lift with a helium balloon or quadcopter. This arrangement allows using the kiwi to 'probe' an area to measure e-field without having the measurement polluted with noise from other than the probing antenna/receiver. It doesn't eliminate differential noise, such as noise on the power supply or LAN but I've found the Kiwi itself to be quite good in this regard.
Although I've thought about using a BeagleBones with on-board wifi to accomplish this, I've found that a small USB Wifi adpator, such as TL-WR802N does the job just fine, is small and inexpensive, so I seen little incentive for kiwi redesign. What we have can work great as it is.
OK, you;ve been there and done that with a USB dongle.
Can you give us a short rundown of what it took to get it running?
I have a fear of having to stretch my weak knowledge of Debian to make it work.
Chuck
I do notice that the model I used, which was around US$25 when I got it on Amazon|e-bay, may be at end of life. Perhaps the adapter that Jim suggests is better, I don't know what it takes to make that work. I was concerned about total weight so something even lighter would be better. Jim, can you comment on what it takes to make the ADAFruit one work?
Using the right dongle model is (apparently) essential. Installing additional software packages may be necessary. A least one mention from someone who has done it successfully exists on the forum: http://forum.kiwisdr.com/discussion/comment/6047/#Comment_6047
Is that the correct model number?
My hope is a USB dongle that plugs into the Beagle's USB.
Chuck
With an ethernet or USB network connection ssh into the kiwisdr, plugged in the D-Link tried lsusb command, not installed
sudo apt-get install usbutils
.....for lsusb etc.
lsusb command now lists the D-Link and notes the Realtek chipset Rtl8192SU with vendor and product
quick Debian search for this chipset to find required firmware
sudo apt-get install firmware-realtek
......D-Link firmware
sudo apt-get install iw
.....tools
sudo apt-get install wireless-tools
..... iwlist etc.
sudo apt-get install wpasupplicant
........for encryption
sudo apt-get install wavemon
...... a valuable tool for displaying local wifi networks
Added the D-Link wifi interface configuration to /etc/network/interfaces
something like...
auto wlan1
iface wlan1 inet dhcp
wpa-ssid "SSID of router"
wpa-psk "password"
alternatively setup wifi with command line tools, or install a network manager. I tried connman works well
sudo apt-get install iw tools
ifup wlan1 worked fine
Andy
Using USB wifi almost completely eliminates the crud and spurs previously seen above 10 Mhz and especially above 20 Mhz.
I will soon be migrating all of the Kiwis at my quiet sites KPH and AI6VN/KH6 to use USB wifi.
Thank you very much Andy!
Rob
Is that the correct model number? My hope is a USB dongle that plugs into the Beagle's USB.
The WR802 is technically a 'stand-alone' but physically it is quite small and pretty light,around 60x60x20mm total with the PCB itself smaller and thinner, not as small as a small USB WiFi dongle though.
>I wonder if this would be better than using a usb adaptor?
Hopefully we are talking about something like the £8 D-Link USB wifi dongle DWA-131 thumbnail sized dongle that was mentioned and just plugs into the USB port.
This should be cheaper than replacing Beagle board and easy to retrofit.
Other wireless dongles may work if the Debian repositories have the appropriate firmware. The chipset type, Vendor and Product ID's used in the wireless dongle can be identified from the "lsusb" (list USB) command once the usbutilities files have been installed.
root@kiwisdr:~# lsusb
Bus 001 Device 002: ID 07d1:3303 D-Link System DWA-131 802.11n Wireless N Nano Adapter(rev.A1) [Realtek RTL8192SU]
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
root@kiwisdr:~#
If the commands I posted on July 12th are not sufficient I could try and elaborate - maybe on Skype. I've run Linux for 20+ years and the Kiwi runs Linux so it's easy to get carried away and assume the wifi installation on Debian is straightforward for all.
SSH is available from Windows 10 - probably installed, otherwise System > Apps > Optional Features , scroll down to OpenSSH client. SSH access through the Windows Power Shell by typing "SSH root@kiwi_IP"....typically SSH root@192.168.1.xxx
Best to ensure that the USB client network route described in the Kiwi documentation is functional, just in case, because eventually the ethernet cable needs to be disconnected and ideally ethernet prevented from starting automatically to avoid confusion as Linux will usually prefer to route to the Internet via ethernet. Access via the USB client network is a good long stop.
If the wireless interface is managed through the /etc/network/interfaces text file, also best to backup this file before editing.
As you say this is easy to retrofit by removing the wireless dongle and changing the /etc/network/interfaces file back to original...but SSH comms are needed - loosing SSH comms is the biggest risk - but three routes (ethernet, wireless and USB) are available.
Andy G3TDJ
Then you have a 'get out of jail card' in case anything goes seriously wrong.
I've always done this as my Linux skills are minimal, and it's allowed me to recover the situation when I've made a mistake and things have not worked as they should.
I think for£8 it's worth having a go.
N150 Mbps ?
It's better not to get too recent with wireless devices as the Kiwi uses Debian "Jessie" which is two version behind the current Debian and the kernel used is unlikely to support recent hardware.....There is a post on another thread where somebody had updated the kernel to get a Kiwi wireless dongle working on 5 GHz. After update the dongle worked on 5 GHz but the Kiwi did not run.
Andy G3TDJ
A better alternative if you want to try that route is perhaps the BBBW, the WiFI version of the standard BBB. But none of this has been tested and is not supported by us if you have problems.
I installed all of these without any problem
apt-get install connman
Edited /etc/network/interfaces
auto wlan1
wpa-psk "password"
Checked the install
root@kiwisdr:~/Beagle_SDR_GPS# lsusb
Bus 001 Device 002: ID 2001:3319 D-Link Corp.
Looks OK - BUT........
root@kiwisdr:~/Beagle_SDR_GPS# ifup wlan1
wpa_supplicant: /sbin/wpa_supplicant daemon failed to start
run-parts: /etc/network/if-pre-up.d/wpasupplicant exited with return code 1
Failed to bring up wlan1.
Any ideas what to try next ?
ifconfig
This should list all the network interfaces...eth0, usb and hopefully a wireless interface
Also ..
ifconfig -a
will list active interfaces
I'm hopeful that the wireless interface will show as wlan0. Although mine came up as wlan1 with the D-Link dongle, yesterday I took another wifi dongle from the junk box, an aged Netgear WG111v3. This configured OK in the kiwisdr, but as wlan0...otherwise worked "out of the box" no extra drivers required, the driver is in the kernel
Talking to Rob yesterday, his wireless dongles in the Kiwisdr are showing as wlan0...and working OK
If your wireless interface shows as wlan0, you will need to change both mentions of wlanx in /etc/network/interfaces
Connman is an alternative to managing the network through the /etc/network/interfaces file. Very good documentation on line and much more versatile.
I'm slightly surprised that the lsusb command did not give you more information on the wireless dongle...this is mine
root@kiwisdr:~#
Andy G3TDJ
It's not listing the wireless interface.
root@kiwisdr:~/Beagle_SDR_GPS# ifconfig
eth0 Link encap:Ethernet HWaddr c4:f3:12:b9:fa:95
inet addr:192.168.1.107 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::c6f3:12ff:feb9:fa95/64 Scope:Link
UP BROADCAST RUNNING MULTICAST DYNAMIC MTU:1500 Metric:1
RX packets:11641 errors:0 dropped:0 overruns:0 frame:0
TX packets:12739 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:2594344 (2.4 MiB) TX bytes:7561229 (7.2 MiB)
Interrupt:175
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:195 errors:0 dropped:0 overruns:0 frame:0
TX packets:195 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:20131 (19.6 KiB) TX bytes:20131 (19.6 KiB)
ifconfig -a
Also try ...
rfkill list all
to see if the wireless is hard or soft blocked
Can't remember if rfkill is installed ...will check my kiwi
Andy
RX packets:12651 errors:0 dropped:0 overruns:0 frame:0
TX packets:13503 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:2720786 (2.5 MiB) TX bytes:7664827 (7.3 MiB)
Interrupt:175
RX packets:223 errors:0 dropped:0 overruns:0 frame:0
TX packets:223 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:23517 (22.9 KiB) TX bytes:23517 (22.9 KiB)
usb0 Link encap:Ethernet HWaddr c4:f3:12:b9:fa:90
BROADCAST MULTICAST DYNAMIC MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0
root@kiwisdr:~/Beagle_SDR_GPS# rfkill list all
bash: rfkill: command not found
I have Connman installed but reading the documentation isn't helping me to configure it.
It's not returning anything
Andy
