- jks
- 29,955
- 212
- Location
- Tauranga, New Zealand RF82ci
- Callsign
- ZL4VO/KF6VO
- Additional information
- KiwiSDR support email: support@kiwisdr.com
SSB Click Frequency
This has been an open issue for almost a year now: https://github.com/jks-prv/Beagle_SDR_GPS/issues/5Basically it is waiting for a "user preferences" capability to be introduced so the tuning method can be varied to individual taste. I'm not going to change the default behavior until then. Otherwise I'll get pummeled with people who don't like the change.. -
Can dx.json be manually edited?
Some important clarification about the directory locations.Anything in /root/Beagle_SDR_GPS will be overwritten with a software update. So do not edit the files in /root/Beagle_SDR_GPS/unix_env/kiwi.config Files here are templates that are copied to /root/kiwi.config exactly once if they don't exist. Because the /root/kiwi.config directory is outside of the /root/Beagle_SDR_GPS directory structure it will not be effected by an update, and it is safe to edit them (and making a backup copy is a good idea).Bonnie, I edited your post slightly to reflect this. -
Interesting Signals
This helps quite a bit: https://www.sigidwiki.com/wiki/Signal_Identification_Guide From our friends at http://rtl-sdr.comA: JORN, Over-the-horizon-radar (OTHR) from Australia. Note the short intro tone in the middle of the passband. This distinguishes it from similar sounding signals like (for me) the Tiger radars of the SuperDARN network etc.http://www.iarums-r1.org/iarums/radar-2013.pdf [10MB file]E, G: FSK/RTTYWould need to hear it or see zoomed in. But you're probably right.Others: Correct I believe. The best blog I know discussing HF digital modes: http://i56578-swl.blogspot.com -
v1.115: reduced audio latency, especially for local connections
Config: v1.113 - Now unable to view Admin pages using iPad [fixed in v1.114]
