wayne
- wayne
- 104
Hi John - Thanks for the autorun addition. Is there still an issue running wspr and ft8 on the BBAI? But there seems to be an interaction issue between FT8 and WSPR on BBAI/AI64 Kiwis. So don't run FT8 on AI/AI64 Kiwis running the WSPR extension fo…
I did a quick test decoding FT8 on 20m with a BBAI capturing 13 other channels for WSPR and also on 1 of 4 otherwise unoccupied BBG channels. The number of FT8 decoded was very close with the winner up by at most 2 counts - usually on the BBAI, but…
John - This is working pretty well on a BBG Kiwi set up to decode on two channels. How much of an efficiency improvement would there likely be running on a BBAI mated Kiwi? I have one of each running now, WSPR is taking up 13 channels on the AI an…
Here's a no-signal FM audio spectra comparison from build 1.577 (presented above) to build 1578. There were no signals on 10m late in the evening to listen to. https://forum.kiwisdr.com/uploads/168/G5K362DSSGDL.png https://forum.kiwisdr.com/uploads/…
https://forum.kiwisdr.com/uploads/382/VNURWXXO5G32.png Looks like the cutoff wasn't long enough.
Jim Lill WA2ZKD suggested trying SDRconsole with the Airspy, so I got the latest version (3.2) and gave it a shot. The curve looks more like the Kiwi, and sounds similar to the Kiwi, but there's still a bit more high frequency response with a modul…
10m was fairly open this morning here in North Carolina and I managed to capture short audio recordings from both the Airspy and Kiwi on the same frequency. The recordings were from the SDR#'s audio recorder and Kiwi's recorder respectively. Both …
Here's what the IC-7300 looks like fed from a dummy load, widest filter BW 15 Khz and no signal: https://forum.kiwisdr.com/uploads/669/I4L0ME1OWEY0.png This rolls off pretty fast too, 20 db/decade by eye.
The last plots I posted were from a frequency with no signal / modulation. I did a 15 minute search on pre/deemphasis and it looks like 6db/octave 20db/decade is the norm. I even found a post you wrote Martin, so you're obviously more experienced …
Sorry Guys, I have too many sound devices on this PC and didn't set the input to the scope properly. With the speaker output loopback selected, these shots look better: https://forum.kiwisdr.com/uploads/088/0TX0D8XB27DN.png https://forum.kiwisdr.co…
FWIW I saw you guys were working on FM demphasis so I rebuilt version 1.577 just now and listened to some FM voice activity on 10 meters, 12khz bw. Compared to a TenTec Orion I the voice "highs" are significantly reduced with the On or +L…
I just found this thread and thought to try one of my Echo Show 8's and it works great! I can type in the IP address:port and the Kiwi UI pops up. To get to the frequency entry window and front panel controls turn off the info panel with the black…
All linear. I measured the 5V and 5Ve pins on the kiwi header while in use 4.36, 4.46 vs 4.32, 4.27 BBG and BBAI respectively. Looked at the schematic and the A/D is set to have a 1 volt input range and is supplied by 3.3 volts. So I don't think …
This adc_ov count is being displayed on the mykiwi:8073/status page, so wd not afactor.
Related question: I have three KiwiSDR's fed from a 4-way mini-circuits splitter, two with BBG's and one with a BBAI processor board. I've noticed that the adc_ov count climbs on the BBAI Kiwi (41 in a day or two) while the two with BBG's stays at …
Changing the sshd_config to add PermitRootLogin yes also worked. Now I can login as root or debian. Thanks again!
https://forum.kiwisdr.com/index.php?p=/discussion/comment/15100#Comment_15100 Awesome idea, that worked, I'm in with debian and a new passwd for that account! Thank You!
Can't log in via putty, connection refused using root as user. Unable to make passwd work via kiwi console. Is there another way to create a non-root account via the console then log in and do a sudo? Debian temppwd doesn't work either via putty
Now that I'm effectively locked out from the OS using ssh, can either the key file or change of sshd_config be done using the console?
Yep, working on chrome again
Fixed the ip problem by commenting out usb0, uncomment eth0: Thanks. Will get to the rest of this later after honeydo. Thanks John
cat /etc/network/interfaces # This file describes the network interfaces available on your system # and how to activate them. For more information, see interfaces(5). # The loopback network interface auto lo iface lo inet loopback # The primary ne…
route Kernel IP routing table Destination Gateway Genmask Flags Metric Ref Use Iface default 192.168.7.1 0.0.0.0 UG 0 0 0 usb0 192.168.1.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0 DeviceDHCP.Home 0.0.0.0 255.25…
It's something with the default port that it goes to for internet I think since it redirects to 192.1.7.2, which is shown as usb0. I'm a bit out of my element here, but will keep plugging away...
Email looks good, I copied content and sent you a message on the forum
John I sent an email with details on a port-forwarded KiwiSDR you can test with. It's reasonably quiet and unused for anything else at the moment. Wayne
Got it. Access seems ok from my static IP now. TNX!
Sent a pm just now with my ip. Had to log on from a hotspot as nordvpn server ops also are quickly detected and blocked too.
Done, thanks
I had a jameco supply fail a while back and that may have been the cause of the corrupted files. In any case, the instructions made perfect sense (I just don't know the git commands) and worked great. I did rm the bad directories after the server …
