fabrys
- fabrys
- 945
- 1
From 23 August 2022 the Guangzhou coastal radio station has reported a change in frequencies as shown in the attached photo. Reporting of unscheduler frequencies with a signal directed towards Europe received by my KiwiSDR: Pt. Reyes Station, Califo…
Update for NMG - New Orleans new transmission frequency 16.027.9 Khz. https://forum.kiwisdr.com/uploads/515/36T1IOAUJ87C.jpg
... my router shows all the peripherals connected in LAN with the same wording: LAN 2 with 1 Gbit / s - LAN 3 with 1 Gbit / s .... the bands are typed from the keyboard, no copy paste .... moreover the error occurs when clicking on the symbol (+) a…
https://forum.kiwisdr.com/index.php?p=/discussion/comment/14250#Comment_14250 "At a guess the bands file has incorrect format/characters." the bands I added were formatted perfectly like the original kiwi bands example: ["23m -"…
.... however I have discovered or I think I have discovered the problem .... because today while I was updating the Admin / Dx card and precisely I was adding the bands, I am not sure of the number because I followed a palan band by categories, but …
I had the BBG that no longer communicated on the net, in short, the KIWI was unreachable. I took a new BBG as a replacement and today it arrived and I tried every possible solution also following the instructions on KiwiSDR Operating Information in …
after re-installing Firefox everything seems to be back to normal
... I try to reinstall the clean Firefox, yesterday evening however it worked perfectly, this morning I re-powering the KIWI with the next update I found this problem. I give you news after reinstalling.
https://forum.kiwisdr.com/uploads/338/EWL7FIKX7655.jpg ... after the last update, on firefox version 100.0 (64 bit), during the connection on the waterfall, white lines appear in full screen randomly, which also affects the fluidity of the waterfall…
Good morning, I don't know if it's just my problem? Firefox browser version 99.0.1 [updated] https://forum.kiwisdr.com/uploads/071/IHFGUQW3BAD6.jpg
... always the same, I thought he was already on the general blacklist, the hi on the local one. However, I see some strange commands than usual. https://forum.kiwisdr.com/uploads/024/WPF5XZNGVK22.jpg
update also for JMH Tokyo Radio from 19 January 2022 the broadcaster has updated the broadcast at 10:19 UTC as an attached broadcast schedule. https://forum.kiwisdr.com/uploads/324/I0JD3LOCOO14.jpg Fabrys
Guangzhou Radio XSQ update from 24 March 2022 the broadcaster has updated the transmission frequencies, leaving unchanged the program and the 1.9 Khz shift to be applied to the frequencies below: 4199.80 8412.50 12629.30 16826.30 For updating th…
@rz3dvp ....thank you!! I had omitted a passage.
Good morning .... I probably make some mistakes, but how come despite adding IPs to my local Blacklist https://forum.kiwisdr.com/uploads/136/WRBCAW4F8DYD.jpg the same IPs still have access to my KIWI? https://forum.kiwisdr.com/uploads/346/PVCDON7L…
The report was referred to you in the forum and not to the provider, which I understand is a waste of time.
... I do not understand if these IPs must be reported [VULTR] to update the list, however I have included it in my local black list. Furthermore, what exactly do lines 3 and 4 indicate? Mon Mar 21 20:19:38 19:31:20.966 0... 0 PWD kiwi W/F ALLO…
https://forum.kiwisdr.com/index.php?p=/discussion/comment/13635#Comment_13635 ... yes I had checked on another IP Reverse site and anyway they are all 3 IP "Vultr". I don't know whether to report to the ABUSE email [OrgAbuseEmail: abuse@c…
... I'm sorry if it's a repetitive question, but I can't always follow the forum information, which is sometimes too technical for me, but these kiwirecorder.py users should be blocked? I state that I have been back online for just 2 hours Thu Mar 1…
https://forum.kiwisdr.com/index.php?p=/discussion/comment/13600#Comment_13600 if you want to hear it, it is now broadcasting on the 3.607 Mhz frequency
... it looks like the MIL-STD-188-141A or Automatic Link Establishment (2G ALE), except that it is not decoded, it would seem a type of encrypted audio rather than a digital only transmission and ends the transmission with a series of morse signals …
perfect. thank's for your job.
excuse the curiosity, but while we are on the subject, to modify or add portions of band on these labels, https://forum.kiwisdr.com/uploads/048/V3V5TEOCMYF6.jpg what is the procedure, I do not know if it is explained in the instructions but I have …
To sum up: The dx.json file should not be damaged if I understand what is reported in the progression of the starting commands of my KIWI, as highlighted below, it is the only line I have found that shows the dx.json. Tue Mar 15 00:48:52 00:00:31.…
https://forum.kiwisdr.com/index.php?p=/discussion/comment/13557#Comment_13557 7,700, maybe I'll get there in 4 or 5 years :-) however, as for the previous post to yours, you keep talking to me about "dx.json", but the answer is always the…
https://forum.kiwisdr.com/index.php?p=/discussion/comment/13556#Comment_13556 Thank you for the information, but I really don't know how to access the directory and perform the operations you suggest. I have no such experience.
https://forum.kiwisdr.com/index.php?p=/discussion/comment/13551#Comment_13551 No, I have not received any messages, as mentioned in the post above it is the only window button that is not accessible, I do not know if it is a problem of the last brow…
https://forum.kiwisdr.com/index.php?p=/discussion/comment/13550#Comment_13550 Yes I have to add it as new otherwise it doesn't change it. No, I just tried to change the type of reception from AMN to AM but the mouse kept turning only on the tag cha…
... yes, but it is a real shame if not for everyone, it certainly is for fans of "wefax" reception. Being one of them, I take this opportunity for an update regarding RBW 41 - Murmansk - Russia. In recent months I have followed it quite co…
