Yes same error. DHCP Masks all the same Ping no issues from none of my systems. I created a solution by editing admin.json from WinSCP. Add admin password and false for autologin.
Indeed solved by Rob, and thanks for all support from the others reacting to my situation. Overload as a result of a strong LW station and many AM signals. Introducing a 15 dB attenuation in the LZ1AQ antenna feed and setting the antenna amplifier t…
Reinstall from factory SD + auto-update to 1.489 no difference, reset around 1h 22 m Thu Feb 24 17:17:04 01:19:41.387 .1234567 /users REQUESTED from 192.168.1.67 Thu Feb 24 17:19:04 01:21:41.325 .1234567 /users REQUESTED from 1…
Ping average all the time also when reset happened 0.684 ms with deviation 0.074 ms. So nothing happening to the network connection. WSPRdaemon is running from (again) another RPi, the 3rd used for testing, so that is not the source of the issue. T…
On the ping did you run it for over the duration of drops? No because I would need to be sitting next to it to monitor the exact moment of the reset to see what has happened just before that on the ping. I could write ping to a text file .. By Ping …
SNR was on without issues, it should not influence connections from wsprdemon of course. I switched it off yesterday, no change in the situation. root@kiwisdr:~/Beagle_SDR_GPS# crontab -l no crontab for root No password so no ssh access from externa…
Stable, 0.6 ms average from same LAN Open from internet but not publicly advertised root@kiwisdr:~/Beagle_SDR_GPS# ct cat: /sys/class/thermal/t*/temp: No such file or directory
I do not see the CPU-temp here : Config: v1.489, 8 SDR channels, 12 GPS channels | Uptime: 20:49:17 | UTC: 18:57 | Local: 19:57 Europe/Paris (CET) GPS: acquire pause, track 4, good 4, fixes 33.5k, ADC clock 66.666520 (33.5k avgs) SNR: All 14 dB, HF…
ADC clock66.666519 (33.0k avgs) Up20:29:57, v1.489, 8 SDR ch, 12 GPS ch GPSacq yes, track 7, good 3, fixes 33.0k WF22 fpsAudio48.0k, Qlen 5 BB55,16,25 usi%1.0 GHzFPGA29%
Doing nothing else, I have had word from other users for a different Beagle AI? that this heralds the complete failing of the Kiwi/Beagle hardware within a few days ... I have now switched off all channels but 1 wspr and see what happens. The reset …
Same with the WD 2.10k after an even shorter period Wed Feb 23 17:27:05 19:18:46.811 ..234567 7 TLIMIT exempt local connection from 192.168.1.82 Wed Feb 23 17:27:05 19:18:46.811 ..234567 7 PWD kiwi SND ALLOWED: config pwd set, but …
Running 2.10k now, let's see what happens. thanks for the reaction James.
Thank you Glenn, n6gn, that worked
I opened the webinterface and made all settings to run the wikiSDR wspr client from my local lan
