Kiwi - wspr extension - setting upload spots
Hi all,
I have a brand new KiwiSDR and try to get it to upload decoded wspr spots via the wspr extension / wspr viewer. The field is yellow and can not be made active.
Any suggestions what setting could be wrong would be appreciated.
The reporter call is different from my main call on purpose to differentiate from other receivers running wspr in parallel.
Thanks
de Erwin
F4VTQ
are you accessing it locally?
I opened the webinterface and made all settings to run the wikiSDR wspr client from my local lan
Have you set the callsign/grid under admin:extensions:wspr?
Thank you Glenn, n6gn, that worked
