Greeting All I have the same problem using the latest SW upgrade, v1.544 (older version too), when running the WSPR Extension while RX0 is running WSPR-Autorun. It runs for a while and then the screen freezes and I have to reload the webpage. Also …
JKS - Hello again ! Where you say ===> "Okay. So it sounds like I need to test the direct laptop connection stuff again. It was always a little problematic. The Kiwi docs have a section on network configuration, but it is a complex topic: …
Greetings All ! Well, problem SOLVED! I finally went back to basics and reconnected the KiwiSDR to my router instead of directly to a laptop. At power-up it started blinking out 192.168.001.103 When that address was accessed the KiwiSDR responded …
Hello JKS Well, I ran both of your suggested websites and nothing found using my.kiwisdr.com. The kiwisdr,com/scan/ site ran thru the 192.168.1.0===>255 and found NONE as the final scan result. After another "power-up' the Kiwi is blinking …
Hello JKS Thanks for the reply. At power-up after lots of flashing, the LED3 (binary-8) double-blinks for a while before blinking the address. Green and Blue Ethernet LED's are active. I will mess around with the browser at the websites you provid…
