DUC auto update not working
I turned on the DU?, but for some reason it only works manually when click on restart DUC, and the auto update does not work.
The log shows that the periodic update does not occur.
Should every update session be visible in the log?
What can I do or check?
  • I think it's fine. If you run noip2 manually it shows updates at the set interval (I tested the 5 minute update interval).
    When it is run in the background it doesn't generate log messages on each update. Also, the noip.com website doesn't change the update time unless the ip address changes.
