My Installation after years of evolving
4 X KiwiSDR with BB-Ai, 2 dedicated to WSPR/FST4W and 2 for public access
GPS-NTPd
Mikrotik managed Switch with Fiber feed to main LAN
6-way GPS distribution
HF antenna distribution from 2 antennas
Pixel Loop with integral LNA
OE-254 VHF vertical dipole converted to HF with Mini-Circuits LNA in shack
Various HB and surplus HPF, LPF and Notch filters
All PSU are Linear
with the latest wiring cleanup, a new RF noise search can commence!
  • edited January 28
    Would you like me to send you an 8-way isolating, active GPS Distribution board? I think I still have an assembled one left. If you are confident that there is now and always will be zero cross-polution of CM currents among Kiwis, it won't help but if there's a chance for even small noise currents coming out of one Kiwi's RF end being injected back into another's it could remove it. These boards have a great deal of isolation at HF and below.
  • edited January 28
    I'd like to try it as a test.... I have a +40db antenna now
  • Looks really good Jim. Is that enclosure at the end of your kiwi brick a manifold for a larger (quieter) fan, or for shielding, or...?
    John
  • a plenum for a single AC high-quality fan
  • edited May 27
    The next evolution...
    • no more Linear PSU, now using Meanwell Industrial DIN mounted switched
    • GPS distro using Glenn's Board
    • new 4-way splitter for vert dipole antenna system
    • AirSpy HF+ w/Inovato SBC for 10M
