Connect to admin page via wifi
I have my receivers set to run using wifi. They work fine like that with one exception. Of the 3 radios I can only get to the admin page on one of them. The other 2 show this message:
No admin password set. Can only connect from same local network as Kiwi.
Client ip = 192.168.1.1
I only have one network and don't have an admin password set on any of them. I can probably connect again using ethernet and add a password but I would like to try to solve it without doing this if I can. I am able to ssh into each radio using the the coreect user name and serial number. The ipaddress the message refers to is the address of the router.
73
Steve KD2OM
Well, are all of the 3 Kiwis and the computer running the browser on the same wifi with the same local network number? (i.e. 192.168.1.xxx) If not, then that's why you're getting that messages.
Sorry for the delay in answering John, we were overseas and got busy.
yes all of them are the same net, i.e. 192.168.1.xxx
Steve KD2OM
I found the issue. The /etc/network/interfaces file was different between the working and non working radios. The non working ones had a static ipaddress set. I must have done this for some reason quite some time ago and conman didn’t change it.
Steve KD2OM
