New KiwiSDR not showing on sdr.hu [ISP port blocking or router firewall filtering?]
Hello all, if this is the wrong place to ask this question
please tell me where to post.
I have a new KiwiSDR delivered yesterday. I put it together, updated the software to
the latest version, and have good local connection and control. I own several other SDRs and got this one primarily
to allow other users to have remote access.
My intent is to configure this for 3 public and 1 passworded user.
However I cannot get the SDR to show up on sdr.hu.
I have configured as per the "Network
Configuration" on the Quickstart page.
Local IP of the KiwiSDR set to Static and a non-conflicting
Local IP assigned.
Port forwarding of the router set to forward port 8073 to
the static Local IP assigned to the KiwiSDR, also "Both" selected so
that TCP and UDP are included.
I do not have a domain name assigned, so I used my Public IP in the "server domain name or IP address".
"Display your KiwiSDR on sdr.hu?" has the "Yes" button selected (green).
The API key has the Registration I received from sdr.hu.
Using the scanner at
http://kiwisdr.com/scan detects
my KiwiSDR on the right internal IP and port.
Under the Admin page on the Log tab, I see "sdr.hu
registration: WORKED".
When the above did not work I DMZed the Local IP assigned,
still no connection, or at least not showing, on sdr.hu.
When I connect using my Local IP:8073 I connect we.., when I
try to connect using my Public IP:8073 the connection times out.
I am not very network fluent, but if anyone has any ideas where
to look from here I would appreciate hearing them.
Thanks,
T!
