Simple "manual" CAT
HI, in the mean time that a good_fellow_programmer (I am just a push_button_depresser) will make a working CAT I have an idea that could be easy to add.
Description: I copy the FREQUENCY field from a CAT program and paste it into the KIWI FREQ input field.
This way should be very simple in its use of keeping synced the two rigs..
I have just tried to copy from DXLABCommander my actual freq and pasted into the input filed of the KIWI.
But it does not work because the copied text is in form of 10.100 Mhz and the KIWI input field accepts the megahertz the text without the fullstop ie 10100.
Who likes that idea hands up please.....
73
Phil IC8POF
73
Phil IC8POF
in awaiting for a full_CAT.
COPY manually from 3rd party program and PASTE into FREQ_Field of KIWI.
...simple no?!...
I have either MicroHam interface and DXLab_Commander programs running.
Both have the FREQ field in the vise of xx.yyy,zzz(mhz-khz-hz) and the KIWI accepts XXYYY in Khz.
In the ol' days of BASIC language I would have solved with one or more : IF field_freq xx.yyy (string$ of 6 chars) OR xxyyy THEN field_freq_sdr = field_freq
or something else and so on, but today I have no idea how do that.
Will write to Dave, AA6YQ DXLab developer and see what he says.
Phil IC8POF
Hence my idea of a "manual_CAT" copy&paste manually in the meantime a full_CAT program sees the light.
The problem is that your field freq input takes xxyyy and the others are xx.yyy.
If I paste xx.yyy ie 10.100Mhz into the kiwi freq_field it assumes 10.1 Khz
There would be ONLY the need to convert the string xx.yyy into xxyyy
.... just an idea.... between thousands
73
Phil IC8POF
I was trying in the wrong direction : from the CAT software toward the KIWI.
The working path is: get FREQ(copy) from the Logger program and paste into the KIWI input field.
That is all.
With ONLY 6 mouse clicks I have the KIWI sync_ed to my radio.
Now do we wait for a fully working CAT.
73
Phil IC8POF
ps: not only for HAM ...
Phil
Could you describe how to make this?
I am very interesting in using KiwiSdr with logger N1MM. Is it possible?
73 Mariusz
