Ant Switch extension on v1.671 [fixed in v1.672]
edited April 20 in Problems Now Fixed
I have noticed that when the extension is configured to 'Switch to default antenna(s) when no users connected' and 'Deny antenna mixing?' is set to 'Yes', when returning to a vacant radio, both the default antenna and previously selected antenna are selected.
This isn't the behaviour I would expect and it is undesirable.
  • Hey, thanks for the bug report. I'll make sure that gets fixed. Unfortunately I had to rewrite a lot of the code that depended on the extension framework. And this has led to all sort of problems.
  • Ha,
    I also noticed that problem, this afternoon, when I changed the existing default antenna to another.
    I think this may be the same as the problem I reported, where I had to turn mixing on and back off again to restore normal operation.
  • Which antenna switch backend? GPIO?
  • Yes, GPIO
  • Okay, fixed. Will be in the next release. Thanks guys.
  • Okay, I can confirm all works perfectly in v1.673.
    Quick question, is it possible to choose a specific antenna in the DX Label?
    I can select the extension, but can I also specify which antenna?
  • I thought it was possible by adding the appropriate command into the extension part of the DX label editor.
    e.g. ant_switch,3
    However, I couldn't get it to work, but I may have got the syntax wrong.
  • OK, using ant followed by a comma and then the antenna number does work.
    If you edit the DX label, you may then have to refresh the browser session before the switch command will function.
  • Yes, the syntax Martin gives, which is the general way to invoke an extension when a label is clicked, will still work for the antenna switch even though it is no long actually a formal extension.
  • edited April 23
    The syntax works. However; the first time in a browser session it works, but after changing the antenna and then clicking on the DX label it doesn't switch to the appropriate antenna, you have to refresh the browser.
    I may have to video this behaviour to make it clear.
    Should I start a new thread?
  • No, let me try it here and see for myself.
  • I see the same behaviour on my home sdr, 198kHz is tagged to select Ant 2.
    http://g8jnj.zapto.org:8073
  • Okay, I see what's wrong. Fixed for the next release..
  • edited April 24
    I woke up this morning and both my Kiwis are on v1.674, but the DX label switching isn't working now.
    Otherwise, the Ant Switch is working.
    EDIT; I have just seen your other post about v1.674 and you have changed the syntax from ant_switch,3 or ant_sw,3, to ant,3. After editing my DX Label to reflect that, it then does in fact work.
    Thanks for the quick resolution of the issue, very much appreciated.
  • I missed that Martin was using ant_switch, the full name of the old extension. The extension name selection code allows for unique prefix matching. That's why specifying just ant alone works. I will make my fix for the DX labels do the same so ant_switch will be accepted as well.
    Also, to be consistent, I should really allow for the other former extensions to be specified in the DX labels as well (noise blanker/filter, waterfall control). Although the use cases for those in that context is much more limited.
  • It all works fine for me now, so I am happy. ant,1 makes total sense.
