v1.666 Shift-click bandwidth adjust appears to be broken when in Audio FFT mode. [fixed in v1.671]
edited April 16 in Problems Now Fixed
Steps:
Load an 8-channel KiwiSDR that puts you into Audio FFT mode. (You must be on channel 2-7 for this to happen.)
Hold shift and click on (+) or (-) zoom buttons to try to adjust IF bandwidth in any mode.
The IF bandwidth does not change.
The Shift-P and p key combinations still work to control IF bandwidth.
Daz.
  • Okay. To be honest I didn't even realize that worked in AFFT mode.
    All that code was revisited because auto-aperture mode was incorrectly allowed in AFFT mode and worked improperly (like turning the entire display black when the sliders were first changed). So in AFFT mode the aperture menu is now disabled. But those changes also caused the zoom icons to stop working too. So I'll fix that.. Thanks.
  • Thanks John.
