Alness no signal
Hi. No reception possible from Alness Sdr. All I get is a hiss. Please can someone sort it? Thank you
  • Can you be more specific? A search on rx.kiwisdr.com for "alness" turns up nothing.
    Also, you may have to contact the Kiwi owner/admin if there is an email link in the user control panel "stat" tab (assuming they're not reading here). A disconnected antenna is really only an issue they can sort out.
  • The nearest one I can find on the KiWi map is this one, and it is a bit of a mess, but so are a lot of the others, one of mine included :-(
    http://kiwisdr.yensaw.net:8073/
    No admin details but there are some if you use the /status info.
  • Sorry I was nit more specific. It was thus one I was referring to
    'http://kiwisdr.yensaw.net:8073/'
    May be a broken or disconnected aerial. No reception if Inverness.
    Another Scottish one nit working is 'http://kiwisdr.dhmitchell.com:8073/'
    Thus close to Edinburgh
    Thanks for your help
  • Add /status to the end of the URL string
    e.g.
    http://kiwisdr.yensaw.net:8073/status
    The fourth line down should give the admin's email address.
    It doen't seem likley that they are on this forum, so try sending them a private message.
