v1.614: admin console improvements
v1.612,613,614 July 5, 2023
  Admin console improvements:
    Can now paste from system clipboard into console (e.g. shell or text editor).
    Mac: Use the usual command-v key.
    Windows: Use the usual control-v, but type it twice in quick succession. This is because
      control-v is used by the "nano" text editor for "page down". So there needs to be a
      way for a control-v to get through that is not interpreted as a system paste. And this
      is accomplished by typing control-v once, instead of twice, within a small time window.
    The bottom line of the admin console tab displays a summary of these changes.
    Many fixes to the ANSI command interpreter. This makes full screen programs like htop
    (alias 'ht') and text editors work much better.
  ALE-2G extension: Test function runs every 4 hours as a workaround to prevent scanning lockup.
  • Hi John.
    Has anyone else reported audio underruns/waterfall stalling/Qlen jumping to 6 for about 2-3 seconds when trying to save/update presets, since the last update?
    I have noticed this is the case since [at least] the latest update, even when no other users are connected and no recording is in progress. Today was the first day I've tried adding a preset in ~2 weeks, so I'm not sure which version this started happening on. I know I did not have this issue on v1.603, though.
    I had made no config changes before this started happening. DX admin page does not report any errors in any presets.
    My Kiwi is running on a BeagleBone Green, if that matters at all. I tried rebooting it (the BBG itself) to no avail.
    My connection to the Kiwi is via LAN, using Firefox, and I notice no other performance issues other than when trying to save presets.
    Here are a few log snippets:
    Sat Jul  8 01:26:58 00:01:23.322 0..       cfg_save_json tcfg:/root/kiwi.config/dx.json 364933|364934
    Sat Jul  8 01:27:03 00:01:28.508 0.. 0     SND: audio underrun 2 ScratchMoney -------------------------
    Sat Jul  8 01:27:03 00:01:28.508 0.. 0     SND: audio underrun 3 ScratchMoney -------------------------
    Sat Jul  8 01:27:03 00:01:28.508 0.. 0     SND: audio underrun 4 ScratchMoney -------------------------
    Sat Jul  8 01:27:03 00:01:28.508 0.. 0     SND: audio underrun 5 ScratchMoney -------------------------
    Sat Jul  8 01:27:04 00:01:28.828 0.. 0     SND: audio underrun 6 ScratchMoney -------------------------
    Sat Jul  8 01:41:02 00:15:27.280 01.       cfg_save_json tcfg:/root/kiwi.config/dx.json 364933|364934
    Sat Jul  8 01:41:08 00:15:32.609 01. 0     SND: audio underrun 7 ScratchMoney -------------------------
    Sat Jul  8 01:41:08 00:15:32.609 01. 0     SND: audio underrun 8 ScratchMoney -------------------------
    Sat Jul  8 01:41:08 00:15:32.609 01. 0     SND: audio underrun 9 ScratchMoney -------------------------
    Sat Jul  8 01:41:08 00:15:32.609 01. 0     SND: audio underrun 10 ScratchMoney -------------------------
    Sat Jul  8 01:41:08 00:15:32.621 01.  1    SND: audio underrun 2 N5ZEW -------------------------
    Sat Jul  8 01:41:08 00:15:32.622 01.  1    SND: audio underrun 3 N5ZEW -------------------------
    Sat Jul  8 01:41:08 00:15:32.622 01.  1    SND: audio underrun 4 N5ZEW -------------------------
    Sat Jul  8 01:41:08 00:15:32.622 01.  1    SND: audio underrun 5 N5ZEW -------------------------
    Sat Jul  8 01:41:08 00:15:32.720 01.  1    SND: audio underrun 6 N5ZEW -------------------------
    Sat Jul  8 01:41:08 00:15:33.090 01. 0     SND: audio underrun 11 ScratchMoney -------------------------
    Sat Jul  8 01:41:09 00:15:33.639 01.  1    SND: audio underrun 7 N5ZEW -------------------------
    Sat Jul  8 01:43:47 00:18:11.909 01.  1    SND: audio underrun 8 N5ZEW -------------------------
    Sat Jul  8 01:43:48 00:18:12.811 01.  1    SND: audio underrun 9 N5ZEW -------------------------
    Sat Jul  8 01:49:17 00:23:41.787 01.       cfg_save_json tcfg:/root/kiwi.config/dx.json 364933|364934
    Sat Jul  8 01:49:22 00:23:47.140 01. 0     SND: audio underrun 12 ScratchMoney -------------------------
    Sat Jul  8 01:49:22 00:23:47.140 01. 0     SND: audio underrun 13 ScratchMoney -------------------------
    Sat Jul  8 01:49:22 00:23:47.140 01. 0     SND: audio underrun 14 ScratchMoney -------------------------
    Sat Jul  8 01:49:22 00:23:47.140 01. 0     SND: audio underrun 15 ScratchMoney -------------------------
    Sat Jul  8 01:49:22 00:23:47.209 01.  1    SND: audio underrun 22 N5ZEW -------------------------
    Sat Jul  8 01:49:22 00:23:47.209 01.  1    SND: audio underrun 23 N5ZEW -------------------------
    Sat Jul  8 01:49:22 00:23:47.363 01. 0     SND: audio underrun 16 ScratchMoney -------------------------
    Sat Jul  8 01:49:23 00:23:48.010 01.  1    SND: audio underrun 24 N5ZEW -------------------------
    Sat Jul  8 01:50:35 00:25:00.015 01.  1    SND: audio underrun 25 N5ZEW -------------------------
    Any ideas?
  • Yeah, I see what's happening. Fix soon..
  • Nice.
    Thank you, Sir.
  • edited July 8
    As for the ALE-2G extension I can report that with the added Test function running periodically in v1.614 long monitoring sessions are now possible.
    Whereas previously the detections of ALE signals would hang after around 10-14 hours I now have a scan running for 27 hours and counting. Thanks for this addition.
  • Audio glitch problem should be fixed in the v1.616 update.
  • Yes, just tested, John. It's working great again. Thanks for knocking that out.
