10Khz tuning steps
I would like to know how to:
click on + or - button.... to tune at 10Khz jumps like 27185 to 27195 and so on....
I tried it and it goes like this.... 27185 then 27190 then 27200 it is not 10Khz steps its 5Khz steps.
Plz help......
Plz help......
Use alt+right arrow if it is easier.
Create DX labels for the CB channels you would like to tune to. This is the one-click solution you can have.
Creating DX labels is a good solution as the CB channels have gaps between them and don't always follow the standard plan.
In addition there is a mixture of AM / NBFM and SSB in use, so adding the appropriate mode to the DX label is also useful.
Here's my example:
In the admin panel, go to the DX tab.
Create a new bar
Then expand the tab
And add the range for that band, plus the step in kHz, You can set this value for each band
now the far right button + is in the 5kHz CB band
center 100Hz, left 10Hz
greetings
Hi ArturPL,
That's a good solution, I didn't realise you could do that.
I think I'll try that myself.
