antenna switch extension 14-Aug-2022 release: downconverter high-side injection support
Requires KiwiSDR v1.554 or later.
This release adds a "High-side injection" checkbox next to each antenna "frequency scale offset" field in the admin page, extensions tab entry for the antenna switch extension. When any connection selects an antenna with the high-side checkbox set the spectrum will be inverted. Just as it would if the similar checkbox on the admin page, config tab were set.
Note that due to the obvious conflict between the config tab version of the setting and the antenna switch version the config tab version will be disabled when the very first antenna selection is made. It will not be re-enabled until the Kiwi is restarted.
