Power Supply Voltage
Sorry, but an hour or so searching has not produced an answer...
What is the maximum input voltage for this system?
I'm thinking of a 6V lead acid battery, instead of a much more expensive 5V lithium?
A buck regulator should/would allow the 6V battery use without a worry, assuming that the amps required by the Kiwi can be handled by the regulator.
So the answer is 5.8V, the point at which the PMIC will shutdown or refuse to power-up.
Might try running from 6V battery with a diode, as suggested, as a baseline for checking for PSU noise.
