New User, Kiwi not updating.
Hi, I'm a new user.
I've connected to the internet and when I log in via local the following text is displayed:
"Sorry, software update in progress. Please check back in a few minutes.
Or check sdr.hu for more KiwiSDR receivers available world-wide."
When I log in via admin the update page the following text is displayed:
nstalled version: v1.2, built Aug 10 2016 21:12:11
Update to version v1.382 in progress
It been at this status for over two hours.
Can somebody please advise me.
Glenn
Glenn
Cheers
Two other things to check.
Is the SD card removed - it should NOT be present when the KiWi is running normally, it is only required to reflash the KiWi from scratch or for backup purposes.
Try another power supply - many of the unexplained issues with KiWi's have turned out to be due to the power supply not being able to deliver either enough current or the required voltage at the Beagle board. I've found that ideally the power supply needs to deliver 5.4v at the KiWi connector (under load) in order to ensure that the Beagle board receives 5V to start up properly.
I will leave it running overnight as you suggest.
I only installed it today and purchased it with the reccomended power supply. Thats not to say its working properly. I will check the
voltage output if no different tomorrow.
Is there anyway of checling if the radio is communicating and in fact connected to the internet ? I can see it has an IP address on my hub but is there some log you can access via the admin page ?
Glenn
Assuming no power supply or network issues try this: If you can bring up the admin page. Go to the "console" tab. Click the connect button. In the "enter shell command" field at the bottom of the page type "make blog" (blog = build log).
You should see a lot of stuff printed. Scroll to the top and make note of the timestamp. Then look through the messages and cut-and-paste to the forum any errors you might see (especially towards the end of the messages). To determine if the build process is looping wait a bit and repeat the process, looking for an incrementing start time at the beginning of the build messages.
Normally it is a case of logging into your network router and finding the "Port Forward", "Games", or "NAT" settings.
Then it is like OUTSIDE PORT > TO > INSIDE IP ADDRESS | PORT
It is much better if you can make sure the Kiwi always gets the same address, that will be under "DHCP" where the router gives local machines addresses.
I'm betting this is going to be the same problem Tony had a few weeks ago with the github.com domain not resolving to the correct location (or whatever it was -- reviewing my notes now).
Anyway, all good now.
Best Regards to both of you!
Glenn
