Sorry, software update in progress. Please check back in a few minutes.
Bought a receiver. Turned on. We got access to the interface, and it says there is an update that has been going on for several hours already.
What to do in this case?
Do you know how to connect to the Beagle/Linux of the Kiwi directly using ssh/PuTTY? If so, then it would be interesting to know if there are error messages contained in the log from these commands:
Trying to update there, that's what's happening.
Pls help to understand these incomprehensible characters.
https://forum.kiwisdr.com/uploads/Uploader/c4/0c57adea12f982237fcc4204ac8610.txt
Is there a way I can get access via port 8073? Thanks.
One part of the error is a "failed to fetch", that could be the redirect failing to properly direct to a valid source (mine redirects to http://cdn-fastly.deb.deb...........)
Does the file mentioned (http://httpredir.debian.org/debian/dists/jessie-updates/InRelease) come down OK on a normal PC on the same network as the Kiwi?
Oh and to save anymore stupid posts from me just give jks the designer and main man access to it ;-).
