RF Pro-1B Issue Developing
Greetings, I'm using the Pixel RF Pro-1B mag loop antenna with my KiwiSDR and my other radios. It has helped me fight off the local noise that I'm attempting to deal with, but last night for the second time I observed something I cannot explain. As the evening wore on here, the MW portion of the coverage seemed to disappear from the Kiwi and every other receiver attached to the RF Pro-1B. It's as if I had engaged the PAR Electronics BCST-HPF high pass filter. But I hadn't. This morning, all appears "normal". When this occurred previously, I swapped out the RF Pro-1B for my Wellbrook ALA1530LNP NA for a bit. I've not observed anything like it with the Wellbrook. Since the Wellbrook is a part of my "portable ops kit", I'd rather not need it for the Kiwi and others. Has anyone had a similliar experience with the RF Pro-1B?
Thanks!
Mike
Thanks!
Mike
Mike
Mike
Mike
Mike
Mike
>I think half the worlds supply of silicone was used to seal every seam and screw.
So the magic smoke is probably still contained within :-)
At least you can unpick silicone, go on you know you want to do it, and we all want to see what's inside :-)
Appears I was just being a bit too cautious opening the preamp. I'll have to back away from "half the worlds silicone" just a bit.
Mike
Bit of low pass filtering then into a balun followed by 2 x Norton input stage (Q1/2) followed by what seems like a fairly standard push pull broadband amplifier with the transistors hidden under the tabbed heatsinks.
I'm sure I've seen a circuit of the Pixel RF Pro-1B somewhere on the web, but can I find it now........
Been looking also.
Mike
Ron
Also the goop around the left connector is not complete but the box is sealed with silicon so may have drawing moisture as the temperature cycles.
