What does the side to side blue lights mean? [don't install sd card for normal operation]
I'm powering up a replacement Kiwi and I cannot find the IP address with the port search. I wonder if the definitions in my router (port reassignment) from my FIRST Kiwi might be preventing the new one from establishing itself on the net.
After a few min of the blue lights sweeping back and forth, the Kiwi and BB seem to power down.
PS is a high quality 5v linear regulated supply, with #18 G wire interconnect.
Bear in mind the thing will need to reboot to update to the current software, give it time.
If you can get into the router you may have another way to spot it.
1. look for "connected clients" or DHCP addresses handed out
2. change the range of addresses handed out, I.E. if it hands out 192.168.1.10-192.168.1.250 change the range to 192.168.1.100-192.168.1.110 (for example) then you only have ten addresses to check.
I tend to use Angry IP scanner as it is quick but it does need Java to be installed.
Is it normal for the BB/Kiwi to "go dark" if it can't connect to the web?
To recover from this situation: Wait for this process to completely finish (Kiwi powers down), remove the sd card, then power up again. Should run okay after that.
Thank you for the help!
