- KA7U
- 3,402
- 3
How to connect via wifi
The search box in the blue title bar will find lots on the topic. Try wifi kiwisdr in that search.
This post might be quite useful to you: http://forum.kiwisdr.com/index.php?p=/discussion/comment/9270#… (more)
first fan died... how long do these things last- what other cooling alternatives ?
Two of my KiwiSDR units lost the fans finally. So I took them out, blew out the bugs, and put them back together without the fans. Set the two units on edge, with one end elevated 1 1/2" by using a… (more)
DRM Heard
Never know when Radio Purga will come on, or which frequency. It always seems to play the same recorded music.
https://www.dropbox.com/s/bi6mao9n0e2d9un/vokoscreen-2020-11-05_20-09-15.mkv?dl=0 -
Wellgood balanced loop amplifier, (Wellbrook clone).
I have the first Wellgood LNA online @ ;ka7u.no-ip.org:8074 . It is using a 120cm loop made out of 1" (25mm) soft drawn copper pipe. One of the transistors is running hot and might not last… (more)
