- jks
- 36,231
- 639
        Problems with frequency stability
        Please protect your KiwiSDR 2 from the high-level RF fields of nearby transmittersPlease make sure your Kiwi is adequately grounded. So the antenna input protection circuitry has a path to drain any charge it is intercepting. Ideally this would be on the antenna coax near the RF inSMA connector. Or from the Kiwi metal case.The ground connection from a switch mode power supply is likely not earth grounded and the Ethernet cable is transformer coupled with capacitive bypass.
        Suddenly my WSJT-X decode counts are much lowerFor future reference. The conversation continued here: https://groups.io/g/wsprdaemon/topic/my_wsprddaemon_decode_counts/105934346?dir=asc
        Suddenly my WSJT-X decode counts are much lowerSounds like more of a question for https://groups.io/g/wsprdaemon/topics
        Network setup advice neededSorry, I got called away by a conference call. If your Kiwi hasn't updated to v1.677 before 3:00 UTC then when it does it will get the change. If it updated prior to 3:00UTC then go to the admin update tab and do a manual build via the "build now" button. After rebuilding, on the admin network tab you will find a new menu item "power on restart delay (secs)". With values "no delay, 30, 45, 60, 90, 120, 150, 180". The default is/was 30 secs. So try 45 or 60 and see if that fixes your problem. Remember that this delay is only applied after a Beagle/Debian restart, as would occur after a power fail recovery. Thank you! I'm sure others will have this same issue.
