36,739
670
  • v1.806
    @studentkra I rewrote all that code for the next release. It has so many issues to consider and corner-cases it just needed to be redone. Hopefully it will be better.
    studentkra
  • What an impressing radio the KiwiSDR really is.
    Thanks.
    Unfortunately things are not good on our end. And haven't been for a long time. So it's always nice to get a positive message every so often.
    FrankinAu
  • v1.806
    Okay, I see that. Thanks
    studentkra
  • v1.805
    From the CHANGE_LOG file:
    v1.805 March 9, 2025
      Mobile improvements:
        Keyboards shortcuts work again, e.g. a Bluetooth keyboard connected to iPad. (thanks DL3LED)
        Popup keyboard dismissed properly after "return" key pressed (e.g. on "ident" fields)
        Disabled input field auto complete, auto correct, auto capitalize.
      Antenna switch:
        Buttons now turn green for Kmtronic-2ch switch. (thanks Fernando)
        Multiuser/mixing denial notification working again. (Thanks Steffen)
      CW Skimmer extension: New. But consider it experimental as there are a number of problems.
      SSTV extension: Fixed MP mode height issue. (thanks VK3HK, VK3KHZ)
      DX label filter panel: Reset button now clears ident & notes fields.
      Update to satellite table to reflect recent Galileo changes. (thanks F4FPR)
    TremolatstudentkraHB9TMCWA2ZKDG4ZFEjimjackiinitroenginebensonG8JNJ
  • Status of proxy service instability [should be good now]
    Proxy stability update in the first post of this thread.
    smg
