wayne
- wayne
- 160
route Kernel IP routing table Destination Gateway Genmask Flags Metric Ref Use Iface default 192.168.7.1 0.0.0.0 UG 0 0 0 usb0 192.168.1.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0 DeviceDHCP.Home 0.0.0.0 255.25…
It's something with the default port that it goes to for internet I think since it redirects to 192.1.7.2, which is shown as usb0. I'm a bit out of my element here, but will keep plugging away...
Email looks good, I copied content and sent you a message on the forum
John I sent an email with details on a port-forwarded KiwiSDR you can test with. It's reasonably quiet and unused for anything else at the moment. Wayne
Got it. Access seems ok from my static IP now. TNX!
Sent a pm just now with my ip. Had to log on from a hotspot as nordvpn server ops also are quickly detected and blocked too.
Done, thanks
I had a jameco supply fail a while back and that may have been the cause of the corrupted files. In any case, the instructions made perfect sense (I just don't know the git commands) and worked great. I did rm the bad directories after the server …
Logging into the beaglebone via ssh and using the cdp/up commands results in the following failure.... root@kiwisdr:~/Beagle_SDR_GPS# cdproot@kiwisdr:~/Beagle_SDR_GPS# upmake: *** No rule to make target 'stop'. Stop.error: object file .git/objects/…
