ve6jy
ve6jy
684
2
  • I listened again, ready to compare - but the app performed fine. Tried multiple things, all sounded well so have to put it down to some strange one time internet connection issue I guess.
  • comments on version.52 I can't say for sure this wasn't like this on previous versions, but I noticed the AGC action seemed quite slow (I couldn't find a place to adjust that) and it made the first syllable of strong signals to sound somewhat over …
  • I'm finding the app to be very useful, thanks for doing this. I have the key you sent, PayPal didn't forward me to any page but maybe that was adblock blocking something. My initial request is around customization of the band buttons and the server…
  • Price appears to be 500$ US... This seems like a VERY non cost effect solution. Surely there must be a cheaper solution.
    in GPS input Comment by ve6jy July 11
  • I won't be there in person, only virtually.... Also forgot to mention the KIWI automatically integrates the EiBi database lookup.
  • I'll be one of your listeners to the SWLFest.... the ": extras" that the KIWI brings are in the form of the various extensions - included software that live within the KIWI app. Many of these are highly useful for those of us that like t…
  • Thanks again John! Once again you go beyond anyone else to fix my dumb issues!
  • A second KIWI (8175) has become full at v 1.671 and can't update. All are running the original Debian 8.5 The first KIWI (8174) I mentioned in previous posts was reflashed from an older SD card and was able to update to 1.676. It has run for 12 hou…
  • Today (April 19) there have been dozens of solar bursts covering about 6 to 30 megs visible on my KIWI... here's one: https://forum.kiwisdr.com/uploads/715/YQZ5S1OR3D3Y.jpg
  • That is ctl on my font, and it was copied/pasted from the guy who tried it on his system and it worked. But not here. https://forum.kiwisdr.com/uploads/379/MRX093HOB33Z.jpg
  • Well as usual nothing works for me. A friend checked on his KIWI and the command works fine. I even copied and pasted so to remove those errors. It doesn't work on another of my KIWIs either. I am on Debian 8.5. https://forum.kiwisdr.com/uploads/…
  • I am certainly interested, thanks
  • Ah ha, that explains it. Not a problem now that we know what is going on! Overall, it works very well and sure is handy for some of our MARS/CFARS exercises. I even use it with the volume for voice scanning too. Thanks for all the effort you have…
  • The solar noise isn't present during night time when the charge circuit isn't allowed to be active. The IP 8.208.21.34 has been showing up quite often, the location(s) can be from anywhere in the world but the IP stays the same. They camp on 23 in …
    in Why 23 khz? Comment by ve6jy July 2023
  • I certainly can see that trying to cover every combination is a complex one for sure. I think that solution will do the job fine, many thanks.
    in v1.592 Comment by ve6jy April 2023
  • using 1.598 on the 8 ch config, RX 0 and 1 still seem to be used up by the preemptible digital modes... https://forum.kiwisdr.com/uploads/612/DR6JZF5VK0TI.jpg
  • Seems like the update (many thanks for the quick update) did the job, all preempted channels returned fine. The only issue I see is that in my 8 channel configuration, some of the waterfall channels get used up so a new user gets the open channel b…
  • The preemption modes are great, I've wished for that feature for some time. I see some of my KIWI's have varying autorun uptimes, showing preemptions and subsequent reconnections. Yet others only have a few running and several that didn't reconnect.…
  • Latest update... the provider ran a ping test all weekend and things were fine (as expected), but the regular internet was always ok, just not the KIWI's. So I changed routers to an IQRouter. No difference. I went back to the Asus. Mor troublesh…
  • Thanks for the comments. It happens when only 1 user is on... from anywhere, even if that user is me (on the external IP). Can barely get thru 2 minutes of audio/waterfall, sometimes less. Just now, got 26 seconds and then freeze on http://72.172.…
  • Well I spoke too soon.... jinxed it! Issue returned this afternoon - likely right around the time DL7AWL checked! nothing I did (that I know of). I've been using that URL for over a year or so, but I will correct it. Altho it has worked fine with …
  • several days later and all is behaving fine....
  • I got the switch from a friend who set it up (at my request) as a dumb switch as I would be too dumb to mess with it. Yes there is quite a bit running, but it has been that way for a long time and the internet is very reliable so it does very well. …
  • SRW2024 v1.3
  • I have other computers that serve multiple SDRAnywhere, Perseus and various video camera servers, all wired to a 24 port Cisco dumb switch, which go to the Asus RT-AC68u router. I have changed ports on that, in trying to eliminate commonality somewh…
  • Yes, the first thing to check is the last thing one touched.... but in this case I can't think of anything I did. I'm leaning to suspect the ISP did something but I'd like to be able to give them an area to look into first. I was planning to give …
  • That sounds exactly like what has been happening for the last week or so.... Yes I have relay protection for when I transmit. All are wired direct with ethernet. All 4 kiwi's behave the same, yet the internet for everything else is just fine. …
  • I was just experimenting, in admin page, extensions I selected wspr 60m EU for autorun 3 then looked at the status page - it started out on the right freq but when I looked again in a few min it had cycled to 10m and 2 min later had gone to 160m. S…
  • I never ran it any other way than from the autorun/extension admin page. And the IWBP has been running for days without any perceived issues, it was only when I selected 60m Eu for the second slice (in the 4 rx mode as this KIWI isn't listed) that…
  • Only from the admin page, extensions tab.
