n8oou
- n8oou
- 4,953
- 1
JKS,All This thread is super informative and helpful. I hope you will organize the graphics and supportive text here and add this to the official documentation stack for the Kiwi. While I have a fairly good update rate on my Kiwi, I now understand…
I have the WSPR extension autostart on the LF band. I use N8OOU as my reporter callsign. I have on occasion autostarted a second instance on MF using the same callsign. That configuration has worked well for me. Mike N8OOU
John, Thank you very much. I have downloaded and completed a few tests with the revised client code. So far the code has performed as documented. I am working to refine my script and when I think it is good to go, I will post why and how I am usi…
ANgazu Thanks for the link to R8brain. I called the page up and it looks like it would be a solution too. Mike N8OOU
John; Christoph; To answer Christoph, yes I am linux only here, with one exception for the US Tax prep program. Following your suggestion I find sox is installed as part of the Slackware distribution. It is a program I didn't know about, and in th…
John, Thanks a bunch for the quick reply and additional info. I am looking at the directKiwi code, but after reading the blog, I know this is way over my DSP knowledge level. I was thinking I could just find a constant with a value of 12001 and cha…
This morning my kiwi returned the firefox "unable to connect" page. Before reading this thread I did a power cycle on the kiwi. The result was a kiwi screen that told me the browser was using a old cached version of a javascript. I cleared…
Update; The second try terminated after 60 minutes, the 24Hr per IP addr time limit. Mike.
jks, that sounds like a good start to me and would allow for quick band hopping. It should be a simple calculation to convert the wavelength to frequency. Maybe you could tie into the dx.json file and jump to the first matching ident in a future …
OK, Thanks for the explanation. I saw the "user preferences" bug report, I didn't mentally include the band menu with it. An item such as the band menu could lead to much discussion as to if it's main association is with the radio loca…
