clitang
- clitang
- 138
- ReadOnly
Try " Alexa/Amazon/Show, go to Silk" and sometimes you get it back to play your KiwiSDR radio which makes an additional feature no other radio does, so far...
Thanks! Amazon Silk is android 5.1.1, capable of book-marking and browsing both web addresses and IP addresses, but somehow, it doesn't load either kiwisdr.local:8073 or 192.168.1.101:8073, or seems to take forever to load, which is not the case els…
I " Check Now " and got " Installed version 1.558 ", but I was then able to update to v1.559, using Debian command lines without any problems. And now I am working on v1.559.
Thanks! I was good with " gbr ", " gurl ", until " gcoms " where I got data of the previous versions, though I was sure I was on the master branch all right. After which I experienced a restart of the server (probably …
root@kiwisdr:~/Beagle_SDR_GPS# gcoms 5a9e4ec 2022-08-30 Merge pull request #684 from jks-prv/develop a705ebc4 2022-08-30 v1.557 8f5f8836 2022-08-30 clock correction fix, add "sndw=N" URL param a1a4bf95 2022-08-30 console 2d support in prog…
root@kiwisdr:~/Beagle_SDR_GPS# gst On branch master Your branch is ahead of 'origin/master' by 5 commits. (use "git push" to publish your local commits) Untracked files: (use "git add <file>..." to include in what wil…
So this is what it is: Check now kept getting " installed version " which is v1.557, and " git show origin: Makefile | head -n 2 " kept showing: root@kiwisdr:~/Beagle_SDR_GPS# git show origin:Makefile | head -n 2 VERSION_MAJ =…
root@kiwisdr:~/Beagle_SDR_GPS# git show origin:Makefile | head -n 2 VERSION_MAJ = 1 VERSION_MIN = 556 root@kiwisdr:~/Beagle_SDR_GPS# In addition, I have noticed frequent server disconnections over the past hours and couldn't understand why as my in…
Installed version: v1.557, built Sep 4 2022 09:22:45 No Internet connection? (can't ping 1.1.1.1) Check now got this above. CONSOLE: open connection root@kiwisdr:~/Beagle_SDR_GPS# cdp; git show origin:Makefile | head -n 2 VERSION_MAJ = 1 VERSION_M…
I did think of " the international dateline " which I quickly forgot about, for ISP at server level, until you talked about localized opening windows. I have just checked on my admin interface for new software at 2350 UTC, it remained at v…
"gup" and others. Then the server msg stays that way.
a705ebc4 2022-08-30 v1.557 f5a9e4ec 2022-08-30 Merge pull request #684 from jks-prv/develop 323b3c41 2022-08-09 debugging for ip_blacklist problem f5a9e4ec 2022-08-30 Merge pull request #684 from jks-prv/develop 323b3c41 2022-08-09 debugging for ip_…
These Debian projected commands appear to have worked for updating and I am now on KiwiSDR V1.557.
CONSOLE: open connection root@kiwisdr:~/Beagle_SDR_GPS# cdp root@kiwisdr:~/Beagle_SDR_GPS# ./up No! Don't do from a console connection. Will strand the Beagle. Instead do: m git; mc; m; mi; (restart button) Got this response.
I realized by now, no more print for "m" command at that, simply means updating was completed in its right. Thank you very much for your line-by-line and blow-by-blow instructions which have been very helpful.
Thanks! Jon. I am now updted to V1556!!!!
Shout I try " connect " again?
I remain connected, but mi input didn't print.
I have checked: apt-get reinstall libssl-dev ls -la /usr/include/openssl/ssl.h and then the whole building procces, with m command, until root@kiwisdr:~/Beagle_SDR_GPS# I did try to complete the process, with mi command, but there was no more resp…
clang++-8 -Dv1_556 @../build/gen/Makefile.inc -std=gnu++11 -c -o ../build/obj_keep/edata_always2.o ../build/gen/edata_always2.cpp clang++-8 ... ../build/obj_O3/web_devel.o ../build/obj_keep/edata_always.o ../build/obj_keep/edata_always2.o ../build/o…
root@kiwisdr:~/Beagle_SDR_GPS# ls -la /usr/include/openssl/ssl.h /bin/ls: cannot access '/usr/include/openssl/ssl.h': No such file or directory root@kiwisdr:~/Beagle_SDR_GPS#
-DUSE_SSL -DVERSION_MAJ=1 -DVERSION_MIN=556 -DKIWI -DKIWISDR -DARCH_sitara -DCPU_AM3359 -DARCH_CPU=AM3359 -DARCH_CPU_S=STRINGIFY(AM3359) -DPLATFORM_beaglebone - DPLATFORM_beaglebone_black -DDIR_CFG=STRINGIFY(/root/kiwi.config) -DCFG_PREFIX=STRINGIFY…
root@kiwisdr:~/Beagle_SDR_GPS# m disable unwanted services make: [Makefile:1028: DISABLE_WS] Error 5 (ignored) make: [Makefile:1029: DISABLE_WS] Error 1 (ignored) make: [Makefile:1030: DISABLE_WS] Error 5 (ignored) make: [Makefile:1031: DISABLE_WS] …
1 error generated. make[1]: *** [Makefile:986: ../build/obj_O3/mongoose.o] Error 1 make[1]: Leaving directory '/root/Beagle_SDR_GPS' make: *** [Makefile:87: all] Error 2 root@kiwisdr:~/Beagle_SDR_GPS# At command m, got this error msg and the buildi…
1 error generated. make[1]: *** [Makefile:986: ../build/obj_O3/mongoose.o] Error 1 make[1]: Leaving directory '/root/Beagle_SDR_GPS' make: *** [Makefile:87: all] Error 2 root@kiwisdr:~/Beagle_SDR_GPS# dpkg --configure -a Setting up man-db (2.8.5-2) …
I did work through on the first scheme but nothing happened after many hours. And I did try " build " as well but there is no " monitor build progress " button on the interface with V1486.
CONSOLE: open connection root@kiwisdr:~/Beagle_SDR_GPS# gcoms 14fb6ca 2022-08-25 Merge pull request #682 from jks-prv/develop 0d128c39 2022-08-25 v1.555 cbe92f7d 2022-08-25 build process: improved error messages a8dd8faf 2022-08-25 iframe extension:…
Wondered if this pull was in process and automatically.
Any problems with this?
