Hello John Your help allowed me to successfully add my kiwiSDR to the public space. Thank you for your TIME and knowledge. 73 Dick/w7wkr
Hello again OK, I updated the KiwiSWR to v1.822 Hopefully, you can now access it. 73 Dick/w7wkr
Hello jks I have the same problem as this fellow ===> " GHFNRV September 3 in Your questions answered How do I resolve this issue? Does kiwisdr.com successfully connect to your Kiwi using these URLs? If both respond "NO" then chec…
OF that I am aware, however this website gets widely read ! I am NOT disparaging anyone here though, just cautious and too old to have to dig-out of a messed-with system. Dick/w7wkr I thought I posted this a WEEK ago - guess not -- db
Hello jks The kiwi that I somehow messed-up was restored to 'being userful' after I copied the data from a working kiwi to a miniSD card, inserted the miniSD card into the unresponsive unit, pressed the reset button while applying power and waited …
Hello again ! I do not know if it is safe or wise to reveal my Kiwis access info here. May I send the 'Connect'and 'Network' info to you privately or not ? I would like being able to access the kiwi at the ...120/8073 address thru its router, a Ne…
Hello JKS Yup, I tried different things over the years to get those 'ports' to register YES and gave up. Then during the time one of the two kiwis (at 10.0.0.10:8073 and ...120:8073) started working by responding YES and YES to the check. Then, ju…
Hello HB9TMC and jks Many thanks for the suggestions. ALL of the suggested slider positions, expected colors, etc were correctly set when I gave up on messing with the kiwi a few days ago. Today, when I started working the problem again, WITHOUT m…
Hello JKS No, I want one kiwi at each QTH so monitoring can be done. Since what is now working as expected, I will NOT mess with changing 8073-to-8074 in one unit! Again, THANK YOU for your wonderful support. Dick/w7wkr
Greetings EVERYONE !! After a tremendous amount of support from "JKS" and HB9TMV, I have been able to restore a kiwi that refused to respond to access efforts. After examining ===> http://kiwisdr.com/quickstart/#id-net-reflash I was …
I have misplaced the microSD card. I see it is possible to make a back-up file on a microSD card from a functional kiwiSDR. I have formatted a card and can insert it in the functioning kiwi.. Do I power-down the kiwi and then insert the blank card…
JKs and HB9TMC OK, sorry about not including the baby-steps taken to get the kiwi to the 10.0.0.120:8073 address. I will use the original micro-memory card and start over. and let it 'get smart' all over again WITHOUT interrupting the process. Tha…
Good morning to JKS and HB9TMC Here is a detailed history of the kiwi with the problem: 1 - When I bought it years ago it was used by connecting it directly to a DELL E6510 laptop using an ethernet cable to connect to it at 192.168.8.154:8073 …
jks OK, I tried to ping '192.168.8.154' using a different smart-switch port and new ethernet cable and got the same results - NO contact. Next I connected the kiwi to a DELL E6510 laptop (used daily to run an ANAN-7000dle) and used a command-line …
OH,, regarding the LED's on the ethernet port the one on the right side is OFF and the one on the left side is blinking. Dick/w7wkr
OK, I should have described the configuration more clearly --- At the present time the kiwi blinking-out address 192.168.8.154 is directly connected to a smart-switch and house router via ethernet connections. It is presently DISCONNECTED from a G…
Hello again folks - finally back home from visit to Seattle. The kiwi I had been using with the admin-page 'network' tab set to 8073 has been working for years. When I checked to see if the remote access address ports were working and found both re…
OK, I tried this ===> =============================================== https://forum.kiwisdr.com/uploads/995/1W6VJ663JQSB.png sshdebian@19=============================================== so it looks like this failed https://forum.kiwisdr.com/upload…
Hello again OK, I cycled the power to the kiwi and waited for it to start blinking-out an address. The address is 192.168.8.154 So I entered 192.168.8.154:8074 and the system timed-out. I tried using the my.kiwisdr.com and received this response…
Hello JKS ! I have tried to connect to my second kiwi after changing the two "8073" ports on the kiwi admin 'network-tab'. then after entering 10.0.0.120:8074 the system times out. I can not access my kiwi after making the changes. Is th…
HB9TMC I tried your suggestion and at the NETWORK "Tab" ===> https://forum.kiwisdr.com/uploads/136/KO1WFSIVY4IB.png changed the 8073 for the two ports to 8074 and restarted the device. NOTE: The screen capture displayed above was taken…
Hello Thank you for the suggestion. I will try it and see if it works. 73 Dick/w7wk at CN97uj
Hello Martin Regarding ===> ============================ Does the green activity light on the Ethernet socket flicker ? NO, the green light is steady ON Have you tried ? Yes and get No KiwiSDR(s) found for your public IP address: kiwisdr.local…
John, thank you for this information. I will check my router and see if the PNP is correctly set up. Tu -- Dick/w7wkr
jks - many thanks for the reply. Hah ! I finally found the paper where I had recorded the PW. My 'memory-blanker' was alive and well, but the paper-find solved the problem. Meanwhile, I am searching the 'forum' looking for a solution to the kiwi/a…
Greeting All I have the same problem using the latest SW upgrade, v1.544 (older version too), when running the WSPR Extension while RX0 is running WSPR-Autorun. It runs for a while and then the screen freezes and I have to reload the webpage. Also …
JKS - Hello again ! Where you say ===> "Okay. So it sounds like I need to test the direct laptop connection stuff again. It was always a little problematic. The Kiwi docs have a section on network configuration, but it is a complex topic: …
Greetings All ! Well, problem SOLVED! I finally went back to basics and reconnected the KiwiSDR to my router instead of directly to a laptop. At power-up it started blinking out 192.168.001.103 When that address was accessed the KiwiSDR responded …
Hello JKS Well, I ran both of your suggested websites and nothing found using my.kiwisdr.com. The kiwisdr,com/scan/ site ran thru the 192.168.1.0===>255 and found NONE as the final scan result. After another "power-up' the Kiwi is blinking …
Hello JKS Thanks for the reply. At power-up after lots of flashing, the LED3 (binary-8) double-blinks for a while before blinking the address. Green and Blue Ethernet LED's are active. I will mess around with the browser at the websites you provid…
